Cub Cadet GT2542 doesn't hold charge
   / Cub Cadet GT2542 doesn't hold charge
What is a 'wobbly' ignition anyway?:eek:
Well....the ignition switch isn't stuck into the dash as tight as it should be, but it has always worked fine.
   / Cub Cadet GT2542 doesn't hold charge #12
Might be your issue. Does it have a jam nut on the backside? Is the switch in the grounding circuit for current flow to the battery or maybe I should say, is the switch mounted to metal or plastic?
Additionally, most V twin and single cylinder gas motors used in equipment like yours have basically a solid state alternator. The flywheel has magnets in the outer diameter that excite a stationary coil that is mounted to the block under the flywheel that produce charging current and other than a magnet coming loose (they are usually epoxied to the flywheel), they are pretty much maintenance free.
Jaw Crusher (A59228)
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
DEUTZ MARATHON...
8065 (A55852)
8065 (A55852)
Cummins Engine (A59230)
Cummins Engine...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
