ISO: Woods backhoe 3ph top link components
/ ISO: Woods backhoe 3ph top link components #1
VTM6800
Kubota M6800
Hello, new member here. I have a 2004 Kubota M6800 and a Woods 9000 backhoe that I bought from my grandfather. He always used a regular top link for the backhoe (3ph mount) but I have found it makes the hoe pretty ineffective. I'm hoping to find someone who fabbed their own subframe and may be willing to sell me their old structural top-link components. Anybody?
/ ISO: Woods backhoe 3ph top link components #2
Woods does not offer those parts? There should be a heavy A frame incorporating the lower link mounts and an adjustable but rigid top link mount. This assembly prevents the backhoe frame from raising the tractors hitch linkage. Using a standard tractor top link increases the rush of link failure and injury or death of the operator by crushing.
/ ISO: Woods backhoe 3ph top link components #3
Based on my dealings with Woods (great consumer support for me) they did not make a subframe for the 9000, just a heavy duty top link and assembly called a Saf-T lock like on the left side of the pic.
/ ISO: Woods backhoe 3ph top link components #4
Which is what I was trying to describe, however inadequately.
/ ISO: Woods backhoe 3ph top link components #5
And several years ago my dealer in Fredricksburg, Va found the parts in the system but they were well over $1,000.
/ ISO: Woods backhoe 3ph top link components #8
I have since sold my BH750 and the 3pt mount went with it.
Thanks for the replies. I am aware of the Saf-T Lock setup but was avoiding spending $1000 on all the components from Woods. I will start fabricating my own in a few weeks if I don't locate a used setup somewhere. Does anyone have the heavy duty top link (Saf-T lock or similar) and could tell me the thickness of the steel?
/ ISO: Woods backhoe 3ph top link components #10
I have several of the cloned "Saf-T Lock" setups that NEWBURY shows in his diagram. They came with the Woods 7500 clones that I bought new. Of those 10 Prairie Dogs (made in Bulgaria), nine were the 7500 copies, and one was a 1050 copy, 10-footer.
Of all those units, only one was used on a 3-point hitch, and the enhanced toplink was damaged and replaced once. But that was on a Category 2 hitch on an industrial Case 480LL. All the Prairie Dog hoes came with the enhanced toplinks, but I (or my buyer) made subframes instead.
Here is a photo. I can go get some dimensions. The parts, all unused, would be heavy to ship so fabbing from scratch may be a better way to go.
/ ISO: Woods backhoe 3ph top link components #11
The side braces for the enhanced toplink I showed above at 17mm thick. On the toplink, there is a 3-piece adjustable sandwich of steel. The 2 outer are 12mm thick, and the other one is 15mm, with a welded-on 22mm strong-back to give it a Tee cross-sction. Very strong.
I have a couple of the toplinks and sidelinks left. I have made 3-pt hitch arms out of the side links, by welding heim joints onto the ends.
Thanks for the measurements! I was deciding between 5/8" and 1/2" steel but hearing that settles it. I agree shipping from CA to VT would be cost prohibitive, I'll fab something up soon and try to post a few pictures in case anyone is interested.
PORTER CABLE AIR COMPRESSOR (A63569)
PORTER CABLE AIR...
1996 Ingersoll Rand 185 Compressor (A64047)
1996 Ingersoll...
2023 John Deere Z930M Zero Turn (A63116)
2023 John Deere...
UTILITY BED (A63569)
1986 VIM TACK TANKER TRAILER (A63569)
1986 VIM TACK...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
