JD X749 Dying after 30-45 minutes
/ JD X749 Dying after 30-45 minutes #42
Fuel Sender in tank
New P/N
FUEL LEVEL SENDER, WITH ANGLED CAP
A fuel sender doesn't have anything to do with sending fuel to the engine. It's a float switch that sends a signal to the fuel gauge on the dash.
Now that everybody is mentioning it, the one problem I had with my JD5300 was when it suddenly died, and was caused by the most repulsive looking crap in the fuel pick up line.
Algae. Are you using any kind of biocide in your fuel?
/ JD X749 Dying after 30-45 minutes #43
It could be clogged.
No, to be honest I never have. I guess I will from now on.
/ JD X749 Dying after 30-45 minutes #46
On that thread, their mower deck PTO's are cutting off from over heat. Just wondering if your's has a system that cuts off the whole thing?
Not that I'm aware of. If I hit the brake or back up, it will disengage the PTO, but I haven't seen it ever turn off.
/ JD X749 Dying after 30-45 minutes #48
the only thing that will shut down a diesel engine is the fuel cutoff solenoid which is not the problem because it gets constant power, so it's not that, so it can be a blockage somewhere, or the fuel lift pump is cutting out..
Yes, at this point I'm sure you are right. Now I have to find time and start checking all the lines. But you have to admit... it is really strange that a blockage is stopping it like clockwork after 45 minutes or so.
Some of these units are set up so that if they begin to overheat, the PTO will be purposely shut off to lighten the load.
No, that doesn't apply here, but that is what Kyle was getting at.
That was one of my early tests when it would die. I would immediately disengage the PTO and see if the engine would come back to life, it had no effect. I might be able to get on those fuel lines today and end this once and for all.
Deere 410L (A53317)
Deere 410L (A53317)
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
2017 Ford F-350 Flatbed Truck, VIN # 1FD8W3G66HEB73643 (A61165)
2017 Ford F-350...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2013 Kubota M108S (A60462)
2013 Kubota M108S...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
