which tree pulling tools?
/ which tree pulling tools? #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander1000 6x6, Ego lawn mower and shopping for tractor
/ which tree pulling tools? #2
We are looking to purchase a tree pulling tool to lift buckthorn out and the below ones look reasonable and being considered. Anyone here use them? What do you like or dislike about it?
I've been battling Buckthorn for 20 years. All of those manual tools are labor-intensive and none of them will pull out large Buckthorn. Develop a long term eradication plan based on your situation then use a herbicide spray containing triclopyr. https://dnr.wi.gov/wnrmag/2017/10/Buckthorn.PDF
Thanks rakee. We bag the larger ones but the puller is of course for the smaller ones in our yard.
/ which tree pulling tools? #4
/ which tree pulling tools? #6
/ which tree pulling tools? #7
Piranha tooth bar on the front of the bucket works great for small brush and autumn olive.
Sadly, we don't own a tractor but are looking for tool reviews as listed in the original post. Here is what they look like
/ which tree pulling tools? #10
You might was to consider "pallet clamp puller" for use with your Polaris if you need more power. Do a simple search but they are not for hand pulling.
/ which tree pulling tools? #12
I've been thinking of making a small tree clamp attachment for my backhoe to yank small stuff from 0.25 to 1.00 inch diameter. I'm still thinking about the best jaw design for small skinny stuff, the last thing I want to do is pinch off the stem. I find when I pull stuff by hand I often strip off the bark instead of yanking things out by the roots.
Do any of you have good experiences with a clamp design that works well on the small stuff?
/ which tree pulling tools? #13
Google Image Result for https://images.homedepot-static.com/productImages/942e1bf8-14eb-484c-92d2-9fb26d63eb8a/svn/klein-tools-pulling-grips-support-tools-164-2l-64_1.jpg
May not work on trees, good for wire and cables.
/ which tree pulling tools? #15
At that small size, forget the stem,, simply touch a root with a tooth, the whole plant comes out,,
/ which tree pulling tools? #16
I have small sucker trees, usually poplar or Green ash, growing right beside a full grown tree I want to keep. I cant pull by hand, cutting just prolongs the problem, and my 24 inch ditching bucket is too big for tight spots. Basically I want to get into tight spots and selectively yank small suckers. I wish the tree weeds would just fall out when touched...
We have invasive buck-thorn here and little shoots everywhere. This is the reason we are getting the Pullerbear tool.
/ which tree pulling tools? #18
On something THAT small, use a spade! ----- OR spray brush killer on them. If there that bad---nothing else will grow there anyway.
/ which tree pulling tools? #19
Hey ArlyA,
I have the Extractagator with the "Big Foot" base on it. Works very well on stuff about 1.5" and less. It will give you a workout, especially if you're an old fat guy like me! My only complaint is that the handle could be about 6" longer for a bit more leverage. I've had mine for several years though, so they may have a newer model out.
When I bought mine I looked at the Extractagator, the long handled Brush Grubber and another one similar to the Extractagator whose name escapes me now. Interestingly, I had found a website that compared all three and that person recommended the Extractagator.
I also have a Brush Grubber BG-8. That also works well hooked up to a tractor or a Jeep. I never tried it hooked up to the ATV that I owned for a short while, but have seen videos of people doing that. Again, it works well, but the constant on and off the pulling vehicle gets tiring. Definitely a lot quicker if you have a second person.
For the bigger stuff, I also have a Notch Tree Puller for the tractor.
EDIT: SORRY - didn't realize that this thread went to a second page and that you had already purchased something.
This is helpful Mark. Thanks. I will do a report on it after it goes into use. You are one of the few who use them here. :thumbsup:
Hey ArlyA,
Adams 16T Tender Body (A63118)
Adams 16T Tender...
2016 Ford F-150 4wd 4 Door (A63118)
2016 Ford F-150...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
378909 (A61166)
378909 (A61166)
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
