careyo63
Elite Member
- Joined
- Jan 6, 2012
- Messages
- 2,841
- Tractor
- 77 Yanmar YM2000 63 Ford 2000
When I changed my Hyd. Filter I used JD.303. I had to replace my screen also. Wasn't near as bad in the pic. from Ca.. But it was beat up and bent up! looked as though at some point the screen was replaced. The more I looked at screen mentioned, Which I actually seen the Pic. Yrs. ago is the more I'm sure it was replaced looking at the seam. My old one had a huge Brass weld that sealed it together which I noticed. Replaced the Axle Seal also. I didn't pull the Collar. It had some small pitting which I just went over with emory cloth and that was 11yrs. ago. I get a drip or two that may come out after parking it. Which the wheel catches it or the Tire soaks it up. I still have the new collar but with my luck I would go replace it and then would start to leak even more. Haven't had to add any Hyd. fluid yet. My new screen looked and was made identical to the old one. No removable cap with one O-Ring on the triangular plate. Fredricks HS-4150
