Suggestions needed regarding DIY Sulky for Grillo G110d
/ Suggestions needed regarding DIY Sulky for Grillo G110d #1
anastasie
Member
TM, Romania
Grillo 110DF
Greetings from Romania! I hope everybody is doing fine during this pandemic times!
I would like to make, together with my brother (the handy guy) a sulky for my Grillo G110D equipped with a Berta Flailmower (85cm) and i was searching the internet for ideas. I found one type, used mostly for lawn mowers, in which the operator stands upright and another type where the operator is seated (like the one EarthTools makes).
Could you help me with some suggestions/ideas/answers?
Can i attach the sulky directly to the metal thing/mask where the wheights are? (i have the nut system from an old trailer...)
Would it change the balance/weight center point of the whole machine, and lift up the flailmower?
Or should i attach it to the tractor wheels? Should i use bearings?
I was thinking to make the sulky with a detachable seat. I have a big piece of land, very bumpy and maybe standing while mowing would be better.
I noticed the sulkies for lawn mowers have very small wheels, but there the ground is leveled. Better to have bigger wheels and the distance of the operator from the ground to be about 20/30cm? I have some old wheels 3.50-8 in size, and i could use them...
What do you think about it?
Thank you in advance for your help!
Anastasie
/ Suggestions needed regarding DIY Sulky for Grillo G110d #2
/ Suggestions needed regarding DIY Sulky for Grillo G110d #3
A larger diameter wheel will smooth out the bumps a bit and roll easier.
Hi Guys,
Thank you very much for your suggestions! I didn't have internet for 2 weeks and thats why i am replying now...
And how the attachement should i go for the wheels?
/ Suggestions needed regarding DIY Sulky for Grillo G110d #5
I don't think we have those in the US but I looked up some pictures and it looks doable. It appears as if those machines can be used going either direction, depending on the attachment. The handles and controls spin 180°. Is that correct?
/ Suggestions needed regarding DIY Sulky for Grillo G110d #6
/ Suggestions needed regarding DIY Sulky for Grillo G110d #7
Mounting to the wheels is usually done with post mounts to the wheel hubs similar to the barbell weight posts. Then the sulky is attached to those posts with bearings at the ends of arms. Earth Tools has the design perfected with the one they build.
Yes, i already though of that, but that goes when the engine you dont have a flailmower attached... which puts the engine facing the operator... Thakns!
/ Suggestions needed regarding DIY Sulky for Grillo G110d #9
Here's the one on the Gravely that I had. Used it A LOT.
I also put a seat on the cart and used it more or less as a sulky. Sometimes, I put the 2 together.
Ralph
/ Suggestions needed regarding DIY Sulky for Grillo G110d #10
With the wheel mounted sulky you have to have an implement mounted in order to keep the tractor balanced. If you want to run a sulky with the engine out front, then use a trailer coupler like Earth Tools sells. That locks the tractor to the sulky in a solid connection, allowing for sideways articulation. That's what I use for my sulky and trailer on my BCS, but I don't have a need for the wheel mount design since I don't have a mower.
I can connect the tractor-sulky-trailer-log splitter all hitched as a train. Sometimes I have a large wagon behind the trailer instead of the splitter if hauling lots of cooking or camp gear out to to the fire pit.
Thanks guys!
The sulky made by EarthTools does it have ball bearings where the wheel hubs are (where the barbell weights are mounted)? I live in Europe and ordering the sulky from Earthtools is too costly for me (its expensive anyway...)... so i have to do it myself? If anyone on this thread has the implement at home, could you kindly take a close up photo? Thank you for understanding
KBH Tender (A61307)
KBH Tender (A61307)
UNUSED FUTURE MINI EXCAVATOR WOOD GRAPPLE (A60432)
UNUSED FUTURE MINI...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
500BBL WHEELED...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
