Steep Slope Mowing Questions/Thoughts?
/ Steep Slope Mowing Questions/Thoughts? #21
Crashz: The pictures do not make it look terribly steep. I would not be worried about mowing it; if you can go up and down and find turnaround space above and below you should be fine. Also, to me you have already run the biggest test of all -- you have already done it at least once ! A problem is that photos can be very deceiving and there is nothing ever quite like being there. You really have to call the shots yourself. You will do no harm to your tractor mowing it and, so you need to use low range,,... that's of no concern.
/ Steep Slope Mowing Questions/Thoughts? #22
About 2 decades ago I found a jpeg image on a government website to make a grade measuring tool. It was nothing more than a sheet of paper on a board with a weight that was on a string. You simply put the board on the ground and where the string pointed was the grade. It was part of a document on making forest roads. It really took the guess work out of "how steep is that".
Here it is. The directions say to just glue it to a board and use a 15" piece of string. I used a shorter piece and put a long skinny board on the bottom. This allows me to just place it on the ground to get a quick reading. It's durable enough so I can carry it on my tractor and accurate enough, as we always said as kids, "for government work".
/ Steep Slope Mowing Questions/Thoughts? #23
Grades always look flatter in pictures. That's certainly steep enough to make me mow up and down only.
To deal with poison oak/ivy, in the shower scrub all exposed skin with a washcloth with lots of Dawn dish soap. Do it a couple times. I think Dawn works better than Technu. And since it's cheap you can use lots. The urushiol "poison" is in the oil rubbed off the leaves and stems, so it's like washing oil or grease off your skin. Lots of soap and lots of scrubbing. Don't sit around in your work clothes, and put them in the wash before you get in the shower. I'm very allergic to poison oak and since I started following this protocol I've hardly gotten any, and I've been in it a lot more than before.
/ Steep Slope Mowing Questions/Thoughts? #24
Thanks for the measuring tool. I have a lot of short steep slopes. Sometimes I just go around them and go up.
/ Steep Slope Mowing Questions/Thoughts? #25
GREAT device ! Elegant in its' simplicity. Neat find. Seems to me all of us dealing with steep slopes can use it every once in a while. Thanks for posting it.
[AND of course it originated with the WVa Dept of Agriculture! Right where it would be needed most.]
/ Steep Slope Mowing Questions/Thoughts? #26
I think I need to make one. I have a steep sloped property that I have been cutting tractor trails and this would be so handy to see what I am up against. Thanks for posting.
/ Steep Slope Mowing Questions/Thoughts? #27
I'm definitely going to make one. I plan to use a LONG thin piece of wood that will serve better for aiming purposes than a short one the size of an 8 1/2 by 11 piece of paper. Maybe a good long scrap of plywood ? Sighting over the top at the same angle as the soil of the hillside is the key to even halfway decent accuracy.
One concern: the width of the paper between the dotted lines could be off quite a bit [proportion in width versus length] in the translation during posting the picture, printing the thing and then using it. Distortion and error might get pretty large. However, the rough accuracy is easy to spot check with a common drafting tool to measure degrees. A 30-60-90 triangle is really common among drafting tools and will provide a great check device. The 30 degree point is quite handy, being around 58% slope and essentially at my upper limit for operating a tractor on, even in the best of soil conditions and with great tires and equipment.
Also, you only need to check one angle with a drafting tool because if one is correct then they all will be.
/ Steep Slope Mowing Questions/Thoughts? #28
If you make an improved version please post your design.
/ Steep Slope Mowing Questions/Thoughts? #29
I haven't gotten out to the shed to make one yet but this comes to mind:
This old image provides degrees, % slope and ratio of slope all 3. I think % slope works best for us steep ground chasers.
Just print this out on your pc printer. Trim off the excess paper and mount it on anything stiffer than paper like a piece of thin plexiglas or just a sheet of heavy construction paper and screw or staple that to a yard stick -- the wooden kind you used to get free from the hardware stores. Put the screw for attaching the string in the apex of all the angles. The string will need a tiny weight (I'm thinking black sewing thread with a paperclip on one end...) Maybe a foot of thread. This rig will be a bit more universal than the WVa AG Dept. pictorial template. Same result. [An inclinometer...]
Not something you mount on your tractor but certainly something you walk out to your favorite "I call this one steep" slope and see what it really is.
I did check on my PC screen and (at least as shown on my screen) the earlier posted WVa AG Dept image from kenmbz is NOT distorted and agrees well with a drafting tool.
/ Steep Slope Mowing Questions/Thoughts? #30
Your posted link not working
/ Steep Slope Mowing Questions/Thoughts? #31
I do not know how else to post a picture in TBN. The icon says "insert an image" and I do that and upload the image. It shows on my end when I click on the attachment.
I think TBN [HEY STAFF, YOU LISTENING???] needs to investigate what this VERY common problem is.
Sometimes it shows up as a tiny picture and sometimes it shows up as Text in brackets. Inconsistent even when done exactly the same way.
/ Steep Slope Mowing Questions/Thoughts? #33
Get an 8ft. board (1x2, 2x4), a tape measure, and a small level.
Level the board on your slope. Measure the distance between the board and the ground at the high end. The height in inches will be so close to the % grade the difference won't matter. (If you want exact, make a 100 inch board) For more convenience, make a 50 inch board, then double the high end measurement.
If you want degrees, save this conversion table.
Bruce
/ Steep Slope Mowing Questions/Thoughts? #34
In my case I am trying to determine grade over a distance of say 50ft or more. Often the area of the two points are not easily walkable. Lots of blackberries and other overgrown bush. To be able to 'sight' the distance I need to work 'above' the bushes.
Thanks Al!
This device is nice because its a quick way to get an average slope. The slope I was referencing changes slightly from one end to the other, so having a quick way to calculate it is better than a super accurate way that takes time.
BTW - I tried the dawn trick once. I'll try again. This Saturday, I will approach the neighbor property differently. First I will shower with Tecnu, then apply Ivy block. Maybe the sunblock made the clippings stick to me. Going to wear long sleeves. Then Dawn instead of Tecnu when I get home. Dry scrub with dawn first, then shower.
/ Steep Slope Mowing Questions/Thoughts? #37
If I could get $.05/pound for poison ivy I’d be a multimillionaire. We had some ancient white oak trees 6’ diameter that had poison ivy vines thick enough to cut a 2x4 from.
My botany emeritus professor would eat a leaf after showing it to a new class or spring flower walks in the Smokey mountains national park. Explaining it is a allergen not poison. He was Scottish. My grandmother said that’s how us Cherokee did to it to build up resistance. Probably made for some poor feelings with the whites back in the day.
Be sure to wash all clothing, gloves, shoes, hats, and wipe down areas you touch. You may have ivy mulch on your mowing deck. Sure you are getting paid enough? I don’t get it but have to be careful not to contaminate my wife.
/ Steep Slope Mowing Questions/Thoughts? #38
Thanks Al!
Say Crashz -- Are you staying on the tractor and not walking around in the foliage and you still get the poison ivy?? Of course it will be all over your mower and don't handle those things BUT if you are getting ivy bumps and itches just riding the tractor over the stuff (with 2 or 3 feet between you and the plants) you may be extremely allergic to it. That can be dangerous. I've seen people so allergic that their eyes swelled shut and they had breathing troubles just from getting close to the stuff. You probably ought to ask your family Doc if that is the case. They may have you take preventative pills to keep you from getting it so bad or minimize the sensitivity.
/ Steep Slope Mowing Questions/Thoughts? #39
Sure, you'll just have to hold the straight edge up a little above the brush and eyeball it to get it as parallel with the slope as you can. Maybe take 2 or 3 readings and do a mental average. I think that is easier to do with something around a yard long than a small board. I bought my parts this morning and will post some picts once I am happy with the gadget.
/ Steep Slope Mowing Questions/Thoughts? #40
Looking forward to seeing your contraption.
2008 STOUGHTON ZGPVW-535T-SC-AR 53X102 T/A DRY VAN TRAILER (A59914)
2008 STOUGHTON...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
2015 Chevrolet 15 Passenger Express Van (A62613)
2015 Chevrolet 15...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
EZ Trail 672 Head Cart (A66285)
EZ Trail 672 Head...
2022 CATERPILLAR D1 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
