Kubota hydraulic issues
/ Kubota hydraulic issues
Ahhh, finally a day off to try to tackle this. I was going to try the hose and jug idea but as I was thinking about it I realized the supply and discharge lines to the pump are not hoses. tractor hydraulic pump1.jpg
With the larger pipe being the supply, I disconnected the smaller pipe. When I turned over the engine, I got nothing squirting out of the pump. I'm guessing my next step should be to remove the pump. From there I can check if the pump is ok. If it is, I would assume something is blocking the supply line. I can't imagine what could block it, but it is a 45 year old tractor.
Again, I'm handy but no hydraulics expert. Am I on the right track?
/ Kubota hydraulic issues #22
Ahhh, finally a day off to try to tackle this. I was going to try the hose and jug idea but as I was thinking about it I realized the supply and discharge lines to the pump are not hoses. View attachment 658840
Remove both lines at the pump. since the line on the top of your pump is the suction one, add oil into the open port. Does all the oil just run out or does it drip?
Crank engine and see if there is a squirt of oil expelled. If no oil is expelled, then perhaps the pump drive has failed.
If you can connect into the suction line with a rubber hose, feed the pump temporarily with oil bypassing all the hardware on the suction side.
Dave M7040
I removed both lines and poured some oil in the open suction end. Nothing ran out. The oil just sat in the pump. Of course, I forgot my key and was getting mauled by mosquitos. I'll try running it tomorrow.
/ Kubota hydraulic issues #24
Well that's a promising result. At least the pump has a good internal seal.
/ Kubota hydraulic issues #25
Your not going to get any oil flow if you dont have the pump rotating.
The oil eventually dripped through the pump. This afternoon I put more oil in and turned over the engine. The oil shot out the discharge end. I'm guessing that means the pump is fine. Going back to my previous post, I have to believe something is blocking the supply line. I'll pull the supply line to check for blockage. I would assume that when I remove it, I should have a clean receptacle to catch the transhydraulic fluid. It is new after all. If nothing drains out of the tractor when I remove the supply line, well, that would be another problem. Wish me luck.
/ Kubota hydraulic issues #27
OK. That's good news. The pump might be worn, but it's working.
To recap, check me on this: This is a tractor (Kubota L225) that has had a history of normal hydraulics. Started up this year and neither the FEL nor 3pt worked. You replaced the cleanable filter in the sump, and changed the oil. Disconnecting the lines at the pump showed us that oil poured into the pump housing would sit in the pump for at least an hour and gradually trickle out the outlet. When you refilled the pump and spun the motor, the oil in the pump shot out the discharge port. Is all that right?
That only leaves a few things. One is the supply line itself could be plugged or it could have an air leak in the supply line that is above the fluid level in the sump. That leak could be in the supply line itself or in the fitting where it connects to the pump.... something like a split compression nut or split in the pipe. That's still my best guess.
Yes, if you take the supply line off the reservoir you had better be prepared for it to dump the fluid. It had better dump or else there is some other problem & very wierd. Sure you can reuse it. I've heard that some people run it through a coffee filter... does that work? But alternately you can just let it stand for a day and then carefully decant the cleared fluid for use. You don't have to be super clean. After all, that filter is probably something like 200 mesh stainless wire cloth.
What else could it be? Well, now we are getting into the unusual. I don't know how that model was plumbed, but I know it is an Open Center hydrualic system and those normally have a pressure relief valve at the loader control and also one associated with the 3pt control. If either one of those pressure relief valves is stuck in the open position - unlikely - the oil would simply circulate back to the reservoir without doing any work. But at higher RPM a pressure relief valve normally makes a sort of squealing sound when it is stuck open. Hard to miss. If the hydraulic pump is simply worn, it will still work but just not make much pressure. But even very, very worn, it would still make enough pressure to work the FEL and 3pt - even though they wouldn't be able to lift much.
An even more unlikely possibility is that the loader control valve has failed internally so that the fluid is simply diverted back to the sump by the return hose. I've never seen that.
You may want to consider puttng a "T" fitting with a small 5000 psi pressure gauge where the pressure supply feeds the loader control valve. I've got that permanently on one of my own old loaders. It doesn't tell much other than I can see the pressure in the feed line change when I work the loader. at least tells me that the pump is working.
In retrospect, I would have bet on that cleanable supply line filter you replaced as the culprit (and lost that bet). My next bet goes towards an air leak in the supply line somewhere above the level of the fluid in the reservoir.... either a wear spot in the line or a leaky connector to the pump inlet. An air leak probably wouldn't leak oil out, only air in. Even a pinhole size air leak would do it.
It's pretty easy to sit here all nice and clean and remote while you do the wrench work. Hope you find it!
rScotty
/ Kubota hydraulic issues #28
Your pump passed an important test.
I suggest you focus on the suction side of the pump as that is where more pump problems originate.
If the suction line starts out as steel but at some point changes to rubber hose, focus your attention from that point to the suction filter.
No problem with re using the fluid if you keep it clean.
rScotty provides great insight.
Dave M7040
rScotty, you are spot on in your recap. The supply pipe is all steel. A pinhole is entirely possible. As soon as I get more time and a clean receptacle that will fit under the tractor to capture the oil, I'll pull the supply line and inspect it. I suppose it's also possible the gasket between the reservoir and the supply failed. I was surprised to see there isn't a gasket between the supply and the pump. Either way, I'm making progress. I'm just glad that this is an occasional use tractor. It's been inconvenient not having it, but nothing more.
Thanks so much for your help and knowledge.
SUCCESS!!!!. It appears something was blocking the supply line. I disconnected both ends and blew through it with my portable air compressor. I didn't see anything but oil fly out, but something must have. I reconnected everything, put the oil back in and everything worked. Of course, as soon as I finished, SWMBO had a project for me that needed the FEL. Apparently I wasn't the only one wanting this project done. :)
One last question for those more knowledgeable then me. Over the past few years I've noticed the speed of the hydraulics has been slowing. It isn't really a problem as this is not used for anything but landscape projects around our property. Is it something I should address?
Again, Thanks to all who helped get me on the right track.
/ Kubota hydraulic issues #31
New topic guys. My M4900 w/La 1002 FEL is having a water in the hydraulics & leak problem. I changed everything out, bled my lines and all was well until it spent one night uncovered which shouldn't be an issue but then I cleaned off the control box for the loader since that was where the leak was to "see" the issue. I rinsed it off for 45 seconds, checked the dipstick and the water was literally flowing out of the dipstick hole. A LOT OF WATER AND THEN FLUID. WHERE IS IT COMING FROM. ACCORDING TO MY KUBOTA DEALER MY TRACTOR DOESN'T HAVE AN OIL COOLER so no infiltration there. Any ideas ?????
HI Farmboy, I'm not knowledgeable enough to answer your question, But you may want to start a new thread to get more replies. Good luck
New/Unused Quick Attach Hydraulic Rock Hammer (A61166)
New/Unused Quick...
2025 GIYI GY-P45 Hydraulic Breaker Skid Steer Attachment (A61567)
2025 GIYI GY-P45...
2017 International Prostar 122 Day Cab (A62613)
2017 International...
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A62131)
UNUSED PAIR OF 76"...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
UNUSED SDLANCH 12' X 20' METAL LIVESTOCK SHED (A62131)
UNUSED SDLANCH 12'...
