Mowed fields all day, ended up at emergency clinic
   / Mowed fields all day, ended up at emergency clinic #141
I have had this happen to me just hours after Bush hogging on my tractor here in Texas. Apparently, lots of tree pollen and dust containing spores and fungus accumulates on the vegetation you are mowing, and during mowing, all this becomes airborne. In Texas you can also include chiggers as a problem.
You breath it in, or it gets on your clothes and your skin...creating major alergic response. It is really more prevalent in the spring to early summer time. Also, it gets much worse when using the Zero Turn mower, because your closer to the ground than any tractor.
Wearing dust mask, long sleeved shirt and a scarf around the neck, goggles and leather gloves should help greatly in minimizing this problem.
   / Mowed fields all day, ended up at emergency clinic #142
This. Everything but the goggles (eyeglasses instead) and scarf is my standard attire for mowing.
Plus always a broad brimmed hat. It isn't just for sun. It's also PPE, avoiding gouging my head on the many overhead obstacles in this orchard.
   / Mowed fields all day, ended up at emergency clinic #143
That's why he has a cab.
   / Mowed fields all day, ended up at emergency clinic #144
Wish I could use a cab when mowing. (Photo). But this is an orchard.
Actually, I bought a second smaller tractor for this kind of work that fits under the trees better. Still couldn't use a cab on that one either.
The dust mask is essential for either.
Im sort of embarrassed it happened with a cab.
I have never had an allergic reaction to anything in my life. It was a nice day and I also like to open the rear window to check for any noises or warnings from the mower and I must have let the noxious allergens into the cab that way. :confused3:
But that’s just a guess. :2cents:
   / Mowed fields all day, ended up at emergency clinic #146
The ac is sucking air from outside also ,Maybe both dust and mice in the cab .I thought you might be going going thru menopause.....:laughing:
There is a cab filter, ya goofball :laughing: Menopause is what the old wrinkle face horse ladies I deliver hay are going through :laughing:
Mice doo doo never bothered me before..... if it did, Id a hung it up as a farmer decades ago. :confused3:
   / Mowed fields all day, ended up at emergency clinic #148
Ya but its not that good of a filter if its like the ones in the machines we have looks like a furnace filter ...... you can see thru it ,If its a pleated air filter type then its much better...
Yeah it’s a good cab filter.
I could have a filter the size of a mattress, but if I open the window, it doesn’t matter. :laughing:
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59575)
2007 STERLING...
David White LT6-900 Level Transit, S/N C500926, Model 8834 (A59076)
David White...
2006 Ford F-250 Service Truck (A56858)
2006 Ford F-250...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
