dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,699
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
I'm looking to make a frame for the back of my X738 for a sprayer. I have not yet pinned down the model of sprayer, but it will probably be a 16 or 26 gal unit from Northern. Filled with water that comes in at 128 or 208 lbs plus the sprayer which looks like 25ish. Then add a stainless frame out of angle which might be another 50 lbs at most (more likely in the 20-25 lb range), and I'm looking at a total rear load of 200-300 lbs. Obviously things are still in flux as I have not bought anything yet (other than the leftover SS I have from earlier projects) so I am open to suggestions. Spraying would be primarily for weeds, prob a 2-4-D variant for the most part. So that's the first part I am looking for any advice on.
So the second part is front counterweights. I have some very steep areas I mow, which is why I ended up with the 4wd mower, so I need to make sure I am not going to get tippy with that extra weight hanging off the rear. I could certainly make weights from concrete to hang on the front frame, or I see Deere has them available for like $60 ea for a 42 lb weight, but I may need to buy some additional overpriced bracket to hang those. So how much weight should I be looking to add? I would expect the sprayer is going to have a bigger moment arm as it will stick out more than the front weights. It looks like the overpriced bracket can hold 9 so 378 lbs there. I am guessing that is overkill but really don't have a feel for how much to aim for. Thoughts?
Thanks,
Dave
Thanks,
Dave
