Price Check 03 BX1500 price
/ 03 BX1500 price #1
Mattyboy93
Member
John Deere 770
Found an 03 kubota BX1500 that a guy is selling by me. It’s in fair shape but is functional nonetheless. It has 1100 hrs on the meter which stopped working last year... so maybe 1500hrs?!? Has an FEL and a 54” belt mower which is a bit on the rough side. It will need a power steering seal kit which he says is all it needs from what he sees. He’s asking $5900 and says it’s firm.. Good deal? Or keep looking?
/ 03 BX1500 price
Also are these tractors pretty capable for the size motor? 15hp seems small for a loader.
/ 03 BX1500 price #3
My dad has one, it is very capable for its size, great little machine. I even used it to pull my 50in core aerator once, it was weighted down to the max (about 800lbs) and pulled it fine but was maxed out. I usually pull it with my B2620 but was in the middle of a job with the backhoe and needed to do a customer's property.
They mow good, are well built, extremely maneuverable and the loader is sized well to the tractor.
They definitely hold their value well.
/ 03 BX1500 price #4
If the meter did indeed stop working last year I seriously doubt that 400 hours has been racked up in the meantime. Especially if it's true that the other 1100 hours were accumulated since 2003. That averages out to less than 69 hours per year if you figure 1100 hours divided by 16 years (2003-2019)
/ 03 BX1500 price #5
Tractors used for residential mowing and landscaping average around sixty engine hours per year, so this seems about right.
/ 03 BX1500 price #6
I replaced my hydraulic steering cylinder on my bx2200 a couple of years ago and it was about $165 or thereabouts. It takes about an hour or maybe 2 to replace it if you have trouble unscrewing the tie arms (this is a good time to replace the boots if they are busted). I rebuilt it the first time (the kit was about $35) and without the proper tools, which I don't have, it's about a 4 hr messy job. The part that fails is a 25 cent O ring. I have no idea what a new hour meter costs or how much time it would take to replace but you'd like to everything working, especially the steering.
The steering fails because we load too much weight in the bucket and then drive around turning sharply without a proper counterweight. I'm more careful about it since mine has failed twice.
The pricing of the 1500 is, in mho, for a very good condition unit. This one fails in 3 departments: the meter, the steering and the beat up mower deck. As described, I think $5000 is a fair price. You'll probably have $250 in parts alone in it to get it back to good condition.
If the unit was properly cared for with maintenance by the book (oil, filter, and fluid changes), it should be a good long term machine.
/ 03 BX1500 price #7
Kind of what I was thinking. I know that I'm beginning my 4th season with a John Deere X394 where I mow one, sometimes 2 acres at a time and I'm just approaching 125 hours.
The tractor in question probably does a little more per year due to FEL work. At any rate it's a relatively low hour machine when you consider the years.
/ 03 BX1500 price #8
VIDEO: Is the Kubota BX188 enough tractor for you? - YouTube
Kubota BX1500
2003 - 2005 BX Series
Sub-Compact Utility tractor
Manufacturer: Kubota
Kubota BX1500 Engine:
Kubota 0.6L 2-cyl diesel
Kubota BX1500 Power:
Engine (gross): 15 hp [11.2 kW]
PTO (claimed): 10.5 hp [7.8 kW]
Capacity:
Fuel: 4.5 gal [17.0 L]
3-Point Hitch:
Rear Type: 1
Rear lift (at ends): 1,210 lbs [548 kg]
Rear lift (at 24"/610mm): 680 lbs [308 kg]
Power Take-off (PTO):
Rear PTO: independent
Clutch: hydraulic
Rear RPM: 540
Mid PTO: independent
Mid RPM: 2500
Front PTO: optional
Front RPM: 2500
Dimensions
Weight: 1,213 lbs [550 kg]
Wheelbase: 52.8 inches [134 cm]
Length: 75 inches [190 cm]
Width: 45.1 inches [114 cm]
Height: 69.5 inches [176 cm]
Ground clearance: 5.6 inches [14 cm]
4WD turn radius: 7.15 feet [2.2 m]
Kubota BX1500 attachments:
mowing deck
snowblower
blade
front-end loader
Loader type: Kubota LA181
Height (to pin): 70.1 inches [178 cm]
Clearance, dumped bucket: 52.4 inches [133 cm]
Dump reach: 29.3 inches [74 cm]
Dump angle: 45
Rollback angle: 25
Breakout force (bucket): 772 lbs [350 kg]
Lift to full height (at pin): 398 lbs [180 kg]
Bucket width: 48 inches [121 cm]
Raise time to height: 2.7 s
Lowering time: 2.4 s
Mechanical:
Chassis: 4x4 MFWD 4WD
Steering: hydrostatic power
Brakes: wet disc
Hydraulics:
Valves: 1
Total flow: 5.5 gpm [20.8 lpm]
Page information:
Last update: December 1, 2012
Copyright: Copyright 2016 TractorData LLC
Contact: Peter@TractorData.com
©2000-2016 - TractorData™. Notice: Every attempt is made to ensure the data listed is accurate. However, differences between sources, incomplete listings, errors, and data entry mistakes do occur. Consult official literature from the manufacturer before attempting any service or repair.
ALLEN AR16 BUGGY (A63569)
ALLEN AR16 BUGGY...
Flex King KM 7 Section V Plow (A63118)
Flex King KM 7...
Harlo HP6500 (A60462)
Athey 7-12 Force Feed Loader (A62679)
Athey 7-12 Force...
2006 Mack CV713 Flatbed Truck (A62679)
2006 Mack CV713...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
