Trying to get in to regen
/ Trying to get in to regen
Has anybody tried a scan tool for this XR4046ch? I tried a Scangauge D but wouldn’t read anything or power up.
Thanks
Well I bought a code reader that someone on this forum said it worked on a model same as mine but it wouldn稚 work,so now I will need to take to a dealer to clear the engine derate.
The dealers do have us by the _____ for sure
/ Trying to get in to regen #13
did you get tractor fixed,did they do a forced burn with computer.i have same machine so far no problem
Yes I got it to regen,I have a code reader that I bought and a plug that fits the one on the tractor so I could find out what was wrong.It was the relay for the burner glow plug connection,you can force it into regen without a computer.
/ Trying to get in to regen #15
Awesome. Do you know brand of code reader and where did you find it,I haven’t been able to locate anything.i live in central Alta.
/ Trying to get in to regen #18
Sorry to bring up an older thread but I hated to start another on the same topic. I am having trouble with Regen. Got it back from dealer, they thought they had it fixed, and 4 engine hours later it went back to not wanting to regen. I've kept the throttle up, it shows to go into regen mode, but never finishes. I've had it show that it was regenning for hours and never turning off. Any suggestions? Anyone know this code reader identified above?
/ Trying to get in to regen #19
Not sure about the code reader discussed above. But many people, myself included, have had luck with an ELM 327 reader with the Torque app for Android.
Links:
Amazon.com: Mestart OBDII OBD2 Bluetooth Car Diagnostic Scan Tool Auto OBD Scanner for Android Devices: Automotive
Torque Pro (OBD 2 & Car) - Apps on Google Play
It may not show everything, your mileage may vary. For my tractor, it shows what I need when I need it.
For this issue, you may need your dealers laptop.
Those laptops (rather the software they have on them) interfaces with just about every single system on my tractor. Even started it without physically turning the key. This issue, I believe, is a complete ECU issue. I do not think there is anything physically wrong. That computer just needs a kick in the head!
However, that scanner is cheap enough that it is great for other issues too, like doing some of your own diagnostic, troubleshooting, or monitoring. Its small enough that it fits under the plastic too.
My expensive scanners wont read my tractor at all. Only these cheap ELM 327s with the Torque app.
/ Trying to get in to regen #20
I re-read your post again. I have questions about what is really happening.
How often does your tractor regularly regen when its functioning normally?
I know your tractor has the Shibarua engine with very short regen intervals. But I dont remember how often that supposed to regen.
After 4 hours on the meter, a light comes on the dash indicating a pending regen?
But doesnt actually start the regen?
But then it does show it regenerating for hours without stopping???
Sooooo...... its regenerating but not regenerating?
:confused2:
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
SET OF HANG ON QUICK ATTACH 48' PALLET FORKS (A59823)
SET OF HANG ON...
2017 CHEVROLET SUBURBAN(INOPERABLE) (A60736)
2017 CHEVROLET...
KJ K1220 12'x20' Metal Shed (A60463)
KJ K1220 12'x20'...
