Buying Advice Tractor vs zero turn
/ Tractor vs zero turn #21
I sold my old Gravely ZTR (46" deck) and bought a Deere Z945M with a 60" deck. The Deere is twice as fast as the old Gravely and cuts two times as good.
/ Tractor vs zero turn #22
I figured this would be the general consensus. I agree with everyone痴 points. I appreciate the feedback. My current zero turn is a bit undersized for my needs. Maybe I値l just look to upgrade a hair on the zero turn.
I use the 770 for the 3 pt capability for the garden patch. Front end loaders are hard to find for these and are expensive.
Time wise I cant see a need for a 60" deck on a zero turn for 1 acre. I mow 6.5 acres with my Ferris 52" deck in about 4 hours and I have a boat load of trees and bushes to go around. Travel speed is 9.9 MPH if the lawn is smooth enough to travel that speed. I dont have problem cutting steep slopes with my Ferris as long as it is dry. If it is wet grass or wet ground, it will slide sideways a bit from the tires slipping. My box store Craftsman wouldn't hold on even a 10 degree slope and just drift down hill with full reverse on the uphill side. Weight of the mower and size of the tires makes for it to hold on a slope.
Unless your mower is worn out, I would stick with what you have. I wouldnt go wider than 52 since cost increases dramatically on the 60" compared to 52-54" decks.
The only bad issue with zero turn is steering on wet ground especially on a slope as you likely already know with your 42" deck mower.
/ Tractor vs zero turn #23
Time wise I cant see a need for a 60" deck on a zero turn for 1 acre. I mow 6.5 acres with my Ferris 52" deck in about 4 hours and I have a boat load of trees and bushes.............................
Maybe I'm in the minority here. Mower decks for tractors are still made and sold, so there must be a few others with similar feelings. I tried a couple ZT's and didn't care for them any more than the MMM we had on our first tractor had.
It takes me under 1-1/2 hours to do our 3-1/2 acres with the L4240 equipped with a 90" RFM. Using the 52" ZT in the example above would take over 2 hours. In many discussions there are claims the "I can mow in half the time with my ZT" or something similar. We may only have a half a boatload of trees, and the deck is 38" wider. We do have some trees, sheds, house, creek and a bridge. Picture below.
I enjoy having a piece of equipment that isn't a one trick pony. The FEL will pick a ton, it has an 8' snow plow, hang whatever on the three point and can handle anything that needs done.
/ Tractor vs zero turn #24
All zero turn mowers are NOT one trick pony's, my Grasshopper has a "easy to put on" sno-blower that really kicks azz!!
There are other attachments for it too...
SR
/ Tractor vs zero turn #25
chim, I have several tractors, excavator and mowers . . . the Z-turns rule when in this instance, flat land . . . there is no comparison . . . fast they are.
/ Tractor vs zero turn #26
I can tell you our zero turn (Hustler Super Z with 35 HP and 72" deck) will mow circles my 35 HP tractor with 84" RFM.
It will mow my 8 acre lawn with dozens of trees in just over 2 hours.
/ Tractor vs zero turn #27
The more obstacles you have to mow around, the more time you will save using a ZTR. If you get a good suspension or air seat, a ZTR is tolerable on slightly rough ground.
Check out my $20 seat suspension upgrade thread. I dont have an air seat and I mow bumpy ground and the rubber plugs I installed on my seat mounts made a big difference.
/ Tractor vs zero turn #28
Please post a link.
/ Tractor vs zero turn #29
/ Tractor vs zero turn #30
You have a whole acre of grass. Nothing less than a $7000 ZT at the bare minimum. You want transmissions that can be serviced after 25 or 40 years of use. Those big box ZT's for $3500 only last about 400 hours before they are junk. You will wear one out in 25 years.
/ Tractor vs zero turn #31
First of all, I said earlier I may be in the minority with regard to the Tractor / Zero opinions. I could venture a guess that there are more tractors doing mowing than Zeros though. If I had a business that was 99 percent mowing for others at many locations, I'd have an interest in Zeros strictly because I could get two of them (equipped with grass catchers) on a trailer instead of one tractor and I could likely hire a couple young guys who would like getting paid for racing around on them. I don't have such a business though. I do mow for a widow across the road, and the tractor is not a handicap on that 1/2 acre.
I'm not looking to make converts of those who are happy with their Zeros, and not asking them to scrap them and go with something different. Zeros must work very well for some people or they wouldn't have that cult-like following. When someone suggests that there is more than one way to mow, the knives can come out rather quickly. Just trying to tell the "undecideds" that I found happiness with a tractor, why I have and that it's possible that others could as well. I also enjoy the tractor for tasks other than mowing. It has climate control and is comfortable to operate. It can be used at a leisurely and very comfortable speed and still get a lot done. This allows the mower to do its work without beating the snot out of it. The tractor has all the capabilities with regard to FEL and 3 point equipment that I'll need. After putting a couple hundred bucks into an abused 90" RFM, it mows well, and with the A/C there's no problem with the heat, dust, pollen or bugs. When (If?) Winter rolls around, it'll handle the 8' front blade just fine. It can pick about a ton of whatever I drag home off of a trailer, move dirt, etc.
Most of the data found on the boards is not easily quantified. Statements such as "Will mow rings around...", "Will do it twice as fast as......", "Is the only way to..........., "If you have lots of XXX to mow around........etc aren't really useful. Two people with Zeros have posted their real mowing times. One works out to 36.9 minutes per acre and the other was 15 minutes per acre. Averaging those two would be 25.9 minutes per acre. It takes me 25.7 minutes per acre with the tractor. Using those numbers, spending between the $3,500 and $7,000 mentioned to go with a separate piece of equipment for mowing doesn't appeal to me. Even using only the quicker 15 minutes per acre figure would only save me 10 minutes an acre.
/ Tractor vs zero turn #32
I used a 42" Gravely ProMaster 100 ZTR for 20 years, at our last house in Central Florida and then on our ranch for the last nine years. I would mow open areas of one or two acres and about one acre with a couple of dozen oaks. It would take me 3.4 to 4 hours and I was completely whipped after the experience. I could mow some of the area with my tractor but it was a PITA and there was no way I could mow around trees. When I did try to mow under some trees on the edges, I had to back up the tractor which wasted a bunch of time.
So I pulled the trigger on my commercial duty Deere Z945M (electronic fuel injection) with a 60" deck. I have cut my mowing time to 2.5 hours from 3.5 to 4 hours. The ZTR has enough power and tip speed to knock down weeds four feet high - when they are that high and dense I have to make a couple of passes.
The ZTR is the right tool to mow three of four acres around the house. My tractor and shredder is the right tool to mow the rest of my property.
/ Tractor vs zero turn #33
I like it when I have time to mow my pasture. Grass around the house is mowed with a push mower. a 42" riding mower and a weed eater. My tractor mows everything else with a 5 foot rotary or a 5 foot flair ditch bank mower. I have open station in the south and like to spend time mowing. I can't hear my cell phone when I am on the tractor. I hope to spend more time on it when I do get to retire. Taking an hour less to mow the grass doesn't matter to me.
/ Tractor vs zero turn #34
I figured this would be the general consensus. I agree with everyone’s points. I appreciate the feedback. My current zero turn is a bit undersized for my needs. Maybe I’ll just look to upgrade a hair on the zero turn.
Upgrade: FrontMount 7 Series | Grasshopper Mower
/ Tractor vs zero turn #35
I will mow about 25 acres at an upscale housing complex with a 72 diesel zero turn tomorrow, and I do this every week during cutting season. Theres a couple 5 acre patches, some steep banks along a pond, trails and front & back yards. My Zero turn does them all and way faster than a tractor. For me, it actually gives me back my time and my freedom.
Completely agree. However, when mowing the steep hills make sure they are bone dry; I went down about 60 ft on a wet hill, backwards, sideways, and back and forth. Puckered up like a prune and left grip marks on the handles.
/ Tractor vs zero turn #39
Grasshopper ok, lacks climate controlled cab, wipers, radio, cup holder?
This is not all true... Cabs with heat, wiper and radio are available, but I don't need a cab when I mow grass...
BTW, my GH has cup holders.... lol and that sure is important to get my grass cut!
SR
/ Tractor vs zero turn #40
Well you just beat the ZT by a little bit by using a lot bigger deck. Point proven on how much more efficient they are. I bet I could equal if not beat your time with my 72” zero turn. If it was a fair match of equal decks the ZT would lap your time. If you want to make a lopsided comparison the other way get a 96” zero turn vs a 58” tractor mower and see what kind of difference there is.
2014 PETERBILT 389 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A68363)
2014 PETERBILT 389...
2014 FREIGHTLINER CASCADIA 113 S/A DAY CAB TRUCK TRACTOR (A69167)
2014 FREIGHTLINER...
FUEL TANK (A68842)
FUEL TANK (A68842)
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
Unused 2021 Berti 112in. Handy 230-280 Hydraulic Flair Mower Tractor Attachment (A66734)
Unused 2021 Berti...
