Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,090
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
My steering cylinder on backhoe needs rebuilt. Couldn't get it off as a unit so had to pull cylinder off while leaving rod in place. Noticed a slight bend in rod so I'm on a mission to get rod off to straighten it out.
Rod is held by a pin and the pin has a lock bolt. The pin essentially has a "pocket" in it and a threaded rod screws through the front, snugs into the pocket and then there is a lock nut that tightens up on the front panel.
The nut is sheared off so there should be no or little tension holding the threaded rod. Too short to grab, I've tried to drill in it but bit keeps wondering off... (yes, I tried to center punch a divot and punch keeps glancing off as bolt isn't "flat".
I don't have a welder (but am now considering buying one)
I don't have an acetelyn (or whatever) torch for heat.... just a little MAP plumbers bottle with torch
Can't "take this" to someone who does as I have no steering
Need to drive into town to get a chisel to see if I can bang it around....
Been spraying it with Penetreat for couple weeks now.
Oh, and since this is something like 35 years old, I am going to suspect there is rust holding the bolt in....I don't know why this bolt would be any different than a couple other items that were rusted in their location.
Thoughts??
The last picture is the pin from the other end of the cylinder so this one should be similar.
Thoughts??
