New member looking to replace 8N
   / New member looking to replace 8N #1
Ishkatan
Monrovia
RK37HC and Ford 8N
So, I have 7.46 acres, 1.5 acres in grass, 3.5 acres in tall weeds on a 10-15 degree hill, and the rest in woods on a 100 year flood plane.
My 6 volt 8N is backfiring and starting hard and steering needs new boots, etc... it can probably be fixed up and run forever but I am kind of tired of maintaining it. I want a 30 HP hydrostatic tractor with a front end loader to take my 5 Ft bush hog to the weeds and maybe a belly mower to zip through the grass. Ideally I would get rid of my 46" Murray and just use the one tractor for everything.
I don't revel in mowing so speed of mowing is high on my list of desired items. I already have a plow, post hole digger and grading blade. Someone told me they bought a 30 HP Kioti for $13,500 including front end loader and I am very tempted to try to get the same deal.
   / New member looking to replace 8N #4
Welcome from Oklahoma.
Ken
   / New member looking to replace 8N #5
Welcome to the forum. Have you went and looked at some of the tractors at the dealer. You may also get a trade in on your 8n. Probably $1000 for it.
   / New member looking to replace 8N #6
A kubota L3200 would be a nice tractor for you but you can't get a mid pto so you would have to use a rear finish mower. A kubota L3540 would be good too. You can get a mid pto and run a mid mower. You would probably want a 6' rotary cutter to clear you tires. A Kubota B3200 may be a option too. It is smaller than your 8n but it will pull a 5ft rotary cutter and you can run a mmm on it.
   / New member looking to replace 8N #7
Welcome.
   / New member looking to replace 8N #8
fix the backfireing and hard starting before trading and you will get more money.. though a straight private sale will net you the most.
the back fire / hard start is likely simple wear / lack of maint issues that need to be addressed. ( start with spark and go to fuel ).. usualy palces to look are bad connections in the electrical, worn dizy bushings, and on the fuel side.. dirty needles/seats, restricted fuel flow. )
   / New member looking to replace 8N #9
Wow, I forgot I had joined this site... and the post. I still have the 8N - friend changed the rotor to solid state and set the timing, replaced wiring, got it to stop backfiring and it worked all this time - just for mowing a few times a year, though it ran weak. I learned to live with bush hogging the front yard. :) Recently, I replaced the 6V generator with a 12V Alternator. Lots more power but ... I had to put the points back since the solid state was only 6 volts.
Now I need to figure out how to adjust the timing. Also, rear tires are dry rotting. I can get FREE 13.2X28 tires but .... 2 of 3 have "beards" on the bead. Can that be fixed or is it OK since they have inner tubes? And I am wondering if I can run those on 11.2X28 rims or need new rims.
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
2024 PRO FABRICATION RTM-5.2K-Y REEL TRAILER (A59905)
2024 PRO...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A56438)
2011 Ford F-550...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
