Should I hack the back end of this sucker off, or no?
   / Should I hack the back end of this sucker off, or no? #11
NEVER give a sucker an even break. Just hack it OFF!
Funny how things have to look right for some of us. I always thought of myself as Pragmatic, but I guess it has it's limitations.
You could build a new one with a couple of heavy bolts to attach as you may need it. I once had a few dozen butterfly wings laser cut and formed that I can weld to a nut for a tool-free attachment method.
No, I really don't have a use for trailer moving with the tractor. If I'm bringing something in on my trailer, it's already hooked up to my suv, I just drive it with that wherever it needs to go.
You guys may laugh, but what I do find this thing handy for is referencing a level bucket, I could eyeball that pretty easily with it. Doesn't need to be that long for that, though.
One thing I was thinking with the long length of the receiver tube, could help if I ever wanted to build a boom pole, not that I think I'd need one. Don't want to just hack it off and later go, ahhh, should have left it alone!
   / Should I hack the back end of this sucker off, or no? #14
Since it's already there, I'd keep it, but cut it shorter. Guy that did it probably just had that tube laying around or bought it and didn't want to bother cutting it down.
Personally, I have a 2" receiver on an attachment plate that I can pop on my little machine. I use it quite a bit to move our car hauler trailer around into places where the Suburban can't get into or I don't want to bother hooking up the Suburban. If you've never moved a trailer by pushing it like that, you're in for a treat. It's much easier than moving it behind you. I used to tow aircraft for a living. All sizes, from little 2 seaters to 727's. We always faced the load. So much nicer.
I also use it with a ring hitch to hang chains or straps from. :thumbsup:
   / Should I hack the back end of this sucker off, or no? #15
Response Got on wrong thread. Thunder storms close by! Or Polish Pototoe Vodka.
There's only one thing I should be saying to my tractor when approaching it:
No, never have. I figured pushing it is like backing it up, gotta counter steer it so it don't jack knife, but at least you're not having to look behind while doing it.
   / Should I hack the back end of this sucker off, or no? #19
I think Lisa Douglas may have said that of Elanor, but never about the Hoyt Clagwell Tractor.
   / Should I hack the back end of this sucker off, or no? #20
It's really a pleasurable experience. Like, "Oh man, this is so easy, it's ridiculous." :) Mostly because you can see everything all the time, which was super helpful moving multi-million $$ aircraft.
I used to park my trailer behind my garage, perpendicular to the driveway next to the garage. Can't get it in there with the Suburban. No problems with the machine.
Anyhow, if you ever get a chance to do it, give it a try. :thumbsup:
TEST YOUR BID BUTTON! (A51243)
TEST YOUR BID...
Woods 3 pt RM 550 Finishing Mower (A50515)
Woods 3 pt RM 550...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52128)
Michelin CARGOXBIB...
2020 BROCE BROOM RCT350 SWEEPER (A51242)
2020 BROCE BROOM...
UNUSED FUTURE QUICK ATTACH PLATE GRABBER (A51244)
UNUSED FUTURE...
