How would you [safely] take down this tree?
   / How would you [safely] take down this tree? #111
While we are waiting for the tree to fall down here's a shooting story for you guys. My brother had asked the power company to remove a yard service pole and transformer. Ya ya they would come and do it. Meanwhile it was spring and the irrigation pivot couldn't irrigate because this power pole with a transformer on it was in the way. So my brother decided to remove the power pole himself. He shot off both the ground wire and the service wire right beside the next pole and pulled the yard service pole out of the ground with his front end loader. When the power company showed up several weeks later the power pole c/w transformer and wires was laying neatly on the ground for them to remove. Ya there were words and yes a letter was received about how dangerous it all was but in the end all that happened is that the power company was a lot more prompt about removing abandoned services.
   / How would you [safely] take down this tree? #112
Yea. I had a job for a while whose duties included shooting pine cones off of trees. Or the whole top if we wanted- the trees were not going to be used again in the program so it didn't matter if we damaged them. I was a pretty good shot with a rife then and it was still remarkably hard to do, and not really much quicker than climbing the tree like we normally did.
you do realize that a rifle round can travel more than a mile, and kill someone when it comes down, right?.:shocked:
   / How would you [safely] take down this tree? #113
The title of this thread includes the word "safely". Those who speak of using firearms or explosives aren't being prudent. Wrong tools for a job could result in unintended consequences.
   / How would you [safely] take down this tree? #114
A 12 gauge loaded with birdshot will only travel a couple hundred yards. That poses pretty much no risk assuming its safe for that distance.
   / How would you [safely] take down this tree? #115
Just curious how do you think hazard trees are removed from industrial settings? They blast them if they’re deemed to dangerous to fall that normally they’ll be dead old growth snags.
   / How would you [safely] take down this tree? #116
That thought has NEVER crossed my mind. I assume the folks doing the blasting in industrial settings are professionals, therefore in that case the word "safely" would be true. However, the picture from the OP (an amateur) certainly doesn't look like an industrial setting so your analogy is apples-to-oranges.
   / How would you [safely] take down this tree? #117
In an industrial setting, i'd just take the nearest loader and knock it down.
   / How would you [safely] take down this tree? #118
Yes with today's heavy duty machinery trees aren't much of an obstacle.
   / How would you [safely] take down this tree? #119
There’s still stuff too big and there’s places too steep to send a machine down even on a line. IMG_0481.jpg
One of the smaller snags that got left on that job.
2025 Swict 66in Bucket Skid Steer Attachment (A55787)
2025 Swict 66in...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
New Holland TN75S 4WD 75HP Loader Utility Tractor (A55787)
New Holland TN75S...
Sheets of 12' Tin (A53316)
Sheets of 12' Tin...
2023 Bobcat S76 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50775)
2023 Bobcat S76...
Step Ladder (A47477)
