Kioti ck3510 loader issue
/ Kioti ck3510 loader issue #1
ironhayden86
Member
Moscow, PA
JOHN DEERE MODEL M
I have @ 2018 ck3510 hydro that has two issues since new I have a slight leak of hydro fluid on the bottom side of the tractor by I believe the tranny or pump, I never get a drip but it's wet to the touch and you can smell it when using the tractor. Also when using the loader I have a lot of play in the loader curl cylinders if I step on the bucket the cylinders will spring 1". Also when using backdrag it gives alot till it gets soild. Any idea what the cause of the loader issue. Not sure if the two issues are related or not, any information would be greatly appreciated.
/ Kioti ck3510 loader issue #2
On your loader sounds like it just might be air still in the lines how much have you used it? The loader also has a quick dump feature that can sometimes make it spongy until you cycle the cylinders fully. Do you actually see the bucket curl cylinders come out when you step on the bucket? There is always some slop in the linkage especially fully curled back due to the low angles.
I have 170hrs on the tractor and yes you can see the shaft move about a inch when you step on the bucket. After that it stays solid. But the issue seem to only affect the curl and not the lift cylinders.
/ Kioti ck3510 loader issue #4
I see it in mine too. Lots of things that don't work as nice as the ck20 I had before this one..... Do you also get forward curl drift as you start picking something heavy up? I have to curl back and then center the stick before I try lifting, or it will just curl forward as I lift.
/ Kioti ck3510 loader issue #6
I would have a dealer check out the leak. I had a rear axle leak on my NX and the dealer resealed it and the other side (which wasn't leaking). Less than a year later I got the other side leaking. Kioti ended up replacing both axle housings. This can't be cheap, and had I no longer had warranty coverage I'm not sure what I'd have done. I don't like leaks; they hardly ever get better.
The bucket drift also doesn't sound right. Again, contact your dealer.
/ Kioti ck3510 loader issue #7
Ironhayden86 and TaylorStove Guy - Neither of those conditions sounds normal. Have you discussed it with your dealers? Should be fully covered under warranty.
/ Kioti ck3510 loader issue #8
Check (or get the dealer too) to see if there is a leak around the o ring for the 3 point speed adjustment knob. I thought I had the same issue with a hydraulic system but the o ring was the culprit and my dealer said that it was a common issue. It was also a quick fix. Keep us informed on what the dealer said on your tractor.
/ Kioti ck3510 loader issue #9
I have the same issue with my curl cylinders on a 2017 model ck4010. Drops forward when I try to pick something with weight up. Especially noticable with my pallet forks. My dealer is waiting for rebuild kits for both cylinders...
/ Kioti ck3510 loader issue #10
I just purchased a 2019 CK3510SE HST and had the same issue in regards to the curl, Drove me crazy when trying to back drag using the FEL. The issue is the bucket will curl down faster then the pressure side can fill the cylinder. So then you end up with this huge air pocket in the cylinder. I was told by Kioti to curl the bucket up and then curl it down and wait at the end of each cycle to bleed the air pocket out but unfortunately I could only curl the bucket about 3-4" before an air pocket came back.
My solution was put a flow control valve in the white line on the FEL at the quick connector and set the valve and now no more floppy bucket especially on curl and works excellent on back drag.
Do you have a part number for the valve you used.
/ Kioti ck3510 loader issue #13
Wrote a article about this and posted to my site. All I ask is leave the content where it is at and do not copy the info and paste to another site or location. If you want to you are more then welcome to link to it so others can see the information.
Kioti CK3510SE HST floppy bucket fix
Tmod, welcome to the forum. I read your blog on your website. When you write that Kioti says this condition is normal, or that they designed it that way, I'm curious who you spoke with? Was it someone at a dealership? A technician at Kioti U.S. in Wendell? A regional tech support rep? I certainly would not accept that this is "normal" for a brand new CK3510SE HST. And it is nuts that a new owner would have to modify the hydraulics with a flow control valve in order to achieve proper balance in the circuit! :eek:
Is Kioti corporate actually saying that air is entering the curl/dump cylinders as you dump because the pump can't keep up? If so, is it because air is leaking past the gland seals every time you dump? Seems to me that this is a covered warranty issue, and that there's got to be more to this story. :scratchchin: You are certainly entitled to more than a DIY workaround mod that might conceivably even jeopardize your warranty coverage later on. JMO
As I mentioned earlier in the thread, I have a 2018 CK3510SE HST, as does one of my neighbors. Both tractors have the same KL4030 loader that's on yours. I am unable to replicate the condition you describe on either tractor. No slop in the dump/curl function, either at the cylinders or the wrist pins. No slop or loss of position when back-dragging with the bucket or a grapple.
/ Kioti ck3510 loader issue #14
And that is what I tried to explain to Kioti is others don't have the issue so if it was designed that way how can mine function like it does as well as several others I have talked to but yet 60% of the owners don't have this issue. I talked to three techs at Kioti Wendell and my dealer and another dealer in Oregon.
There is quite a bit of slop in the arms and pins on the loader as well, This is on a new 2019 CK3510 and I know they changed the lift control valve for the 3ph and who knows what they did with the loader hydraulics.
Very disappointed with Kioti in regards to the bucket issue and the extremely jerky 3ph. They just say normal as designed so that leaves me no recourse.
Below you will read actual replies from Kioti and they are saying all the tractors do it I just never noticed it, BS reply but if Kioti states it is normal even though we know it is not it sort of ties one hands for a resolution.
What I sent in first,
"Hi, I had purchased this tractor due to a neighbor having the same tractor but his is a few years older then mine. He has no issues that I have.
The 3 point will judder now and it didn't when it was new, Here is a link to a video showing what i have to go through when I raise my rear 3 point implement. http://www.norwestsuspension.com/videos/Kioti CK3510SE HST 3 point lift.mp4
Now on to the FEL, Seems this thing cavitates when rolling the bucket down, I have tried at 2600 rpm and it still creates cavitation even if I move the bucket a few inches, Almost like the down roll side of the hydraulics has a restriction in it or the pump is not flowing what it should. http://www.norwestsuspension.com/videos/Kioti CK3510SE HST Bucket roll.mp4
So my question would be why did the 3 point not jump when it was new but now with 20 hours it jumps?
Had issues day one with not being able to back drag as the bucket will roll flat.
At this point in time I am very dissatisfied with the tractors performance and feel like I wasted 30K on something that does not perform the way it should."
Kioti Reply
"Thank you for your email. The valve on your 3-point is either open or close. You have to revat high RPM raise up then lower. To eliminate the cavitation tilt the bucket down until it stops this will get the air out of the cylinder.
Best Regards,
Clarence M. Washington II
Customer Service Administrator"
Reply to that statement from Kioti,
"Hi,
I can raise the rpm to 2600 rpm and roll the bucket down and then back up a little bit and it will cavitate and still have air in it, Basically even at high rpm it will cavitate after fully rolling the bucket up and down.
If the 3 point valve is either opened or closed why did it not judder when it was new? Seems like a contradiction that it is normal if I had no judder when new and now I do. Normal doesn't work that way."
Kioti Response to that,
"You might not have noticed it. All of the smaller tractors do this.
Best Regards,
/ Kioti ck3510 loader issue #15
Is anyone still having issues with the airpockets in the FEL of the CK3510SE? I bought a brand new 2020 CK3510SE and it is doing this exact thing. I find it completely unacceptable to work around it by going full up and full down every time I want to back drag. The time wasted and frustration to go through this cycle everytime is beyond me. Come winter I would be fighting that all winter? I'm all set. I got 4 hours on the tractor and it is at the dealer to find a solution. I refuse to spend well over 30k for a tractor package and do work arounds for something that should not be there to begin with. I will update if anything comes out of it but worse comes to worse I am giving the tractor back and will get into something else. I struggled to select Kioti to begin with and wanted tonstick with a Mahindra which I had before but was looking to go bigger and prices were a but out of reach. Thought I would give Kioti a try and so far it is nothing but regret. Hoping a solution is found that is not a work around.
/ Kioti ck3510 loader issue #16
If it get's returned from the dealer with the same issue or they say it is normal as they told me then let me know and I may be able to help you out.
/ Kioti ck3510 loader issue #17
I壇 like to know what your fix was, I have the same issue
/ Kioti ck3510 loader issue #18
Thanks. Apparently Kioti has acknowledged the issue with some tractors and is working on a fix for new tractors and a fix for those tractors that have the problem. I don't have details other than that. I am hoping to get some sort of timeline. Working on a fix is a way of saying tough luck so I am not sure how honest of a reply it was.
/ Kioti ck3510 loader issue #19
Yeah well I was told by my dealer they had a fix for it and sent the tractor in for the update and got it back and the bucket would dump whether you gave it left or right stick. Ended up having to undo what the dealer did myself.
Kioti has had a issue with o-rings blowing under the seat on the hydraulics and it has taken them over 2 years to figure out they needed to change the bolt. Not confidence inspiring.
/ Kioti ck3510 loader issue #20
I've had no issues with mine, purchased last fall - has 69hrs on it, last week received 18 yds. of stone and 18 yds. of loam, moved / spread / back dragged - no issues, the three point may bounce a little when first used but smooths out - I believe mine ended up being a 20 as it had to be shipped to the dealer - it has the new lettered seat. Know a couple of others with CK's they are not having issues - will be following the thread.........
Volvo VNM (A63688)
Volvo VNM (A63688)
McCormick X6.55 (A64126)
McCormick X6.55...
(1) 235/80R16 TIRE W/ (8) LUG WHEEL (A64280)
(1) 235/80R16 TIRE...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
2007 BIG TEX 16 T/A UTILITY TRAILER (A65643)
2007 BIG TEX 16...
