Cranks, black smoke, blips, but won't start?
   / Cranks, black smoke, blips, but won't start? #1
sCaryCary
NH 1925
I borrowed my neighbors NH 7308. Ran for about 45 min. Died on me now I can't get it to run. It crznks, tries to stsrt then dies. I filled the tank. I bleed the injector lines. It blows black smoke. What do I try next?
   / Cranks, black smoke, blips, but won't start? #2
Change the fuel filter, drain out some fuel (water)?
   / Cranks, black smoke, blips, but won't start? #3
Give him a call and tell him what happened. If I loaned out my equipment and you had problems with it, please call before you wrench on it.
   / Cranks, black smoke, blips, but won't start? #4
Oops, I overlooked that it wasn't his tractor. Call the owner.
First do no harm.
   / Cranks, black smoke, blips, but won't start? #5
Check the air filter. Knock out any dust. Ensure you have a clear air passage to the engine intake. Black smoke and a failure to run frequently indicates a very dirty air filter.
   / Cranks, black smoke, blips, but won't start? #6
or packed with a huge mouse nest.
Thanks all. I have borrowed this tractor before. He asked me to service it a year and half ago. I checked the air filter it's OK. Replaced 10/19. Fuel filter looks good. Fuel bowl is full. I did call him. He didn't have any tips or tricks for me. Said I know more about than he does. I charged the battery over night and will give it ago here shortly. Wish me luck.
   / Cranks, black smoke, blips, but won't start? #8
A 7308 is a Ford loader model.
What is the tractor model?
I think it 's a TC29. Anyway I found there was a partial blockage in the fuel line from the tank to the fuel bowl. I blew it out with a air tank. Now it run s like before.
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2006 TerraGator 8104 (A55314)
2006 TerraGator...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
