Morra disc mower
/ Morra disc mower #1
Buddycat68
Grayson ky
Massey ferguson 253,kubota M6040,New Holland TC40DA,Farmall Super A
I have a morra F25-6 mower that I want to change the oil in. Does the cutter bar have its own oil separate from the gear box on the end closet to the tractor or do they share oil? What kind of oil should I put back standard 80w-90 gear oil or something else.
/ Morra disc mower #2
Not familiar with the Morra, but every other brand that I know of has a separate oil supply for the gearbox and cutter bar.
On the Kuhn, you stand it up to drain both. Fill the cutter bar with it vertical, then lower it to horizontal to fill gear box. Yes, I use 80w-90 in both.
I looked online, but didn't readily find a video of the Morra. There are dozens of videos showing the oil change on other brands. If yours is similar, it should be the same process.
/ Morra disc mower #3
I have a Morra rake but no cutter. On my NH disc machine the cutter bar is separately lubricated with drain and fill plugs on each head. It takes 90 weight GL5 gear oil.
/ Morra disc mower
I couldn稚 see any drain or fill plugs on the cutter bar is why I was wondering. Thanks for the help
/ Morra disc mower #5
On my Kuhn, the drain and fill plugs are accessed through a hole in the skid plate. The plug is removed with an Allen wrench. (hex bit)
/ Morra disc mower
Thanks for the help I値l look tomorrow.
/ Morra disc mower
I知 going to look at the bottom of my cutter bar tomorrow I know I can稚 call until Monday.
/ Morra disc mower
I was using my phone to reply wasn't around my computer.
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
John Deere 700 H Dozer (A62679)
John Deere 700 H...
2017 FREIGHTLINER CASCADIA  125 6x4 T/A  SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
LOT OF GRAIN BIN LADDERS (A64278)
LOT OF GRAIN BIN...
2011 International DuraStar 4400 18ft. Cab and Chassis Truck (A64194)
2011 International...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
