Good morning!!!!
   / Good morning!!!! #112,062
Its on on the iPhone and when I hit the paperclip it goes to photos and the when I hit a photo it says "select a maximum of one photo" I hit "OK" then the banner goes away, I select a photo then it says "select a maximum of one photo" - repeat . . .etc . . . stuck in a circle.
In iPhone settings for the TBN "allow photos access" is checked to "read and write".
I only have notifications turned off.
When you get the “select one photo” warning it’s because it’s very sensitive. You have to hit middle of pic, cause it thinks you hit multiple pics, hence the message. IMG_4526.JPG
   / Good morning!!!! #112,063
Will you have to remove your 3-point hitch to re-mount your backhoe?
Unfortunately, yes.
I'll probably end up making some sort of rack on wheels to hold everything. I think all the top'n'tilt plumbing will also have to come back off, too. Perhaps another Craig's List Knack Box and a set of balloon tire casters is in my near future?:rolleyes:
   / Good morning!!!! #112,064
Front yard got mowed.
Another iPhone photo. 99% of my tbn posts are with the iPhone app. It is so much easier to post pics on the phone, if I want to post a pic from my laptop, I copy it to my phone first and then post it.
   / Good morning!!!! #112,065
68°F and .02 inches rain
Play around the tractorshed today. In mount rotary cutter, a good tractor washing, straighten up the tractorshed, maybe back to work on canopy.
Prayers for all with extra for Drew
Be safe
Have a great day
   / Good morning!!!! #112,066
When you get the 都elect one photo warning it痴 because it痴 very sensitive. You have to hit middle of pic, cause it thinks you hit multiple pics, hence the message.View attachment 655765
I'm right-handed and I've found it works better for me if I use my index finger on my left hand to pick the photo rather than my thumb on the right hand, which is what I use to navigate the phone ... :thumbsup:
   / Good morning!!!! #112,067
Possibly Rust-Oleum 209460 Plastic Primer Spray?
Yep, good stuff with a fair amount of acetone in it. I just wish it came in gray as spraying it on something white is difficult to see if you've coated it completely.
   / Good morning!!!! #112,068
Good morning, sun is shining, still need hat and gloves to keep warm in this wind.
Drew, hope you are feeling a little better today and they let you come home.
Mostly, I wasn't sure about lifting the frame over the tank, so I played safe and made it to split into two halves.
LS, was thinking about your staples yesterday when I was removing some from a gate post I was replacing. They go in a lot easier than they come out ! 1600 hammered in one day is going some, hope your fingers soon forgive you for having too much fun in a single day.
RNG, Rick, some people tried making their own Fluid Film. Sadly, they didn't realise lanolin is extracted from the wool after sheep are shorn...
"RNG, Rick, some people tried making their own Fluid Film. Sadly, they didn't realise lanolin is extracted from the wool after sheep are shorn..."
Oops! No wonder the sheep are in a bad mood?
   / Good morning!!!! #112,069
Have you tried clearing Cache within TBN app. Then turning phone off and back on.
Yea Ron, that did it and I also have to touch the phone commands slightly to the left, Thanks BEF.
   / Good morning!!!! #112,070
Unfortunately, yes.
I've considered an LS backhoe for my LS XR4155HC. The LS backhoes are frame mounted so, the 3-point remains in place.
My biggest reservation is how well a backhoe would work with a cab tractor? Don't think I've ever seen one, in person. Unlike your TLB, the LS backhoes have their own operators seat.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
40" X 64" X 72" METAL SHELF (A58374)
40" X 64" X 72"...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
2007 John Deere 5225 56HP Utility Tractor (A55973)
2007 John Deere...
