Good morning!!!!
   / Good morning!!!! #112,051
Possibly Rust-Oleum 209460 Plastic Primer Spray?
Yep that is the stuff. I used the professional line primer, just because I had some already. I honestly feel that their professional line of spray paint is better quality, goes on smooth, dries fast, good coverage. IMHO
   / Good morning!!!! #112,053
Quote— BEF — “ LS that was a lot more staples than I thought needed for 200 ft. Was it 2000 ft?
200 ft is 25 posts at 8 ft, maybe 4 staples per post for welded wire. “
I put in staples horizontally across both of the split rail, also down each post.... about every 4- 6 inches. Ended up almost 250 ft. I estimated about 30 staples a section, plus down the posts. (Also re-stapled another fence at the old house about 100 ft long since I was on a roll! )(forgot to mention that).
Need to keep critters out and dogs in. When we had our big dogs (giant schnauzers), they would pull the wire fence right off so they could go eat the UPS and Fedex guys. I just started doing the fences that way and never had any more problems, so just continue to do the same way.
   / Good morning!!!! #112,054
Its on on the iPhone and when I hit the paperclip it goes to photos and the when I hit a photo it says "select a maximum of one photo" I hit "OK" then the banner goes away, I select a photo then it says "select a maximum of one photo" - repeat . . .etc . . . stuck in a circle.
In iPhone settings for the TBN "allow photos access" is checked to "read and write".
I only have notifications turned off.
   / Good morning!!!! #112,055
Test
Edit: Most of the time (90%) it sends me in a loop, every once in a while it will let me attach a photo. Frustrating.
   / Good morning!!!! #112,056
Good morning to all! Low down to 50, should hit 84 today. No rain forecasted until maybe Tuesday. I am envious of what you guys get... we are exceptionally dry. Fire season is going to be bad!
Dump run still on the agenda, truck is already partially loaded. Then some misc. cleanup / organizing of stockpiled materials. I just cannot throw away usable material... it will get repurposed eventually.
The post and rail materials were originally used as the first fencing when we moved into the old big house 25 years ago. It was in place for about 15 of those 25, then the picket fence went in. I stacked all of it in the back behind the corral for about 10 years, now it is being reused. Only a few pieces were not usable. It was way too expensive to just toss....
Most of my stock pile has been dwindled down... hardly anything left, and plans to use it up in the near future. Then maybe I will relax... sure!
   / Good morning!!!! #112,057
Grey2 does not appear to be very happy with you!
   / Good morning!!!! #112,058
Found this while going through security camera video this morning. Kyle had asked about dismounting the backhoe, and it's clear that there's a lot of fooling around and wasted motion going on. Should be better next time.
Got a text from a neighbor last night that said he'd found a homeless camp down below the house along the abandoned boat launch road. And that there was a new trail that looked like it was leading up here to the house. Haven't found anybody but me on the videos yet, but in a little while I think I'll have a chat with the sheriff's dispatcher and see what they think.
The door to the pump house got left open for a few days a while back, and the camera in there picked up a bat coming and going a few times. So I need to take a good look in there now, too.
Good thing I don't have anything else to do, huh?:laughing:
   / Good morning!!!! #112,059
Good morning. It was 64° and cloudy this morning. Our high is supposed to get to 81° this afternoon.
The storms arrived about 1:30 a.m. I would have slept right thru it but for some loud thunder. We ended up with 1 1/4" of rain in two gauges. I'm happy .. didn't need a 5-6" rain as the weather guessers were predicting. I don't know how much rain we got at the Richmond house.
Once the lightning / thunder woke me up, I watched Iron Resurrection, on the Motor Trend Channel and fell back to sleep about 3:30 a.m.
I did get the 9 acres, around the house completely mowed yesterday with the ZT and poisoned a few new gopher mounds.
Today may be a good day to get the 84" rear finish mower blades sharpened / replaced and grease the spindles, PTO Shaft, and u-joints. I planned to do this a week ago but .. got distracted by other projects.
I also need to pressure wash the porches before the upcoming Memorial weekend.
Hope everyone has a safe and productive Saturday.
Prayers to all.
   / Good morning!!!! #112,060
Will you have to remove your 3-point hitch to re-mount your backhoe?
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2003 McCormick XTX 185 XtraSpeed Tractor (A56438)
2003 McCormick XTX...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2018 FREIGHTLINER...
2016 KENWORTH T680 TANDEM AXLE DAY CAB (A59575)
2016 KENWORTH T680...
