Kill IT!! Deader n' Dead!
/ Kill IT!! Deader n' Dead! #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
I have a couple of areas under and around decks, porches and walkways that just get nuisance weeds and grasses, seeds probably blown in on the wind or deposited by birds. I want the dirt essentially sterile so that NOTHING grows. I've tried all the store shelf stuff and it all fails. Even the Ground Clear that used to be called Trioxx that's supposed to be a ground sterilizer and clear everything out for a year. Used some of the stuff double strength, weeds are back in just a few weeks.
I've even thought about a heavy dose of salt in some places, but that leeches and has other issues such as concrete/foundation degradation.
Ground cloths don't work, weeds grow right through it. And they're not inexpensive. Concrete or other paving is out due to the cost, prep and the potential need to dig the area in the future because of buried utilities. Solid surfaces or poly sheets won't allow evaporation either and this area needs to remain dry. While those products will prevent rain from falling directly on the areas, they won't stop water infiltration from other areas. I need to work on drainage also, but that may be another step that will involve some digging.
Paving blocks that can be lifted out might be possible, but they're costly and weeds still find a way through. I see that even in professionally maintained areas.
But it also has to be 'safe' in that it won't leech beyond the applied areas or seep too deep and affect tree roots. It can't poison birds, rabbits, etc.
I've even tried pre-emergents and products like Preen that are supposed to stop seed germination. They don't work and they don't stop weeds that use sub surface root runners.
I might not even be opposed to non-traditional ideas like laundry products or oils.
I know, I know ... a magic product that kills what I want but nothing else, has no side effects and is cheap.
/ Kill IT!! Deader n' Dead! #2
Hydrogen peroxide will kill it, and is safe.
It stops photosynthesis in the plant.
How much to dilute it, would be the real question. Full-strength will give you what you want, but as to how cheap it is, would remain for you to decide as you dilute it with water. If say, you could cut it with 3/4 water, that would be pretty cheap, but if it had to be nearly full-strength, then your cost per treatment area goes up.
You also might want to try vinegar. That makes the soil so acidic that it will not grow.
Or, you can try cutting the hydrogen peroxide with vinegar...
/ Kill IT!! Deader n' Dead! #3
We built our current house on the exact same spot as the old homestead house. The homestead house was torn down in '52 - we built in '82. The yards around the old house location became "wild fields" in the intervening 30 years.
It's a slow process but it works. I began mowing these wild fields and would buy and spread native grass seed every year. After five years or so - finally choked out the last of the weeds. Now have about two acres of "country" lawn around the house and outbuildings.
It's not your lawns as you will see in a Scotts advertisement. It's all wild grasses - but it's thick, it's green and is a nice lawn when mowed.
I have found no way to sterilize land that will not also present other hazards. At least, that can be accomplished by a homeowner.
But for how long? Weeks, months, annual?
I don't want lawn. I don't want anything. Ultimately, there will be gravel, pavers or something else I haven't figured out yet, but NO GREEN anything.
/ Kill IT!! Deader n' Dead! #5
Be VERY careful with hydrogen peroxide. In concentrated( commercial ) form is an almost explosive oxidizer. I have used the commercial product - experiment to rejuvenate an old seepage pit. It went ballistic. Created a volcanic eruption of sludge and old sewage.
Spectacular to view - very dangerous to be around.
/ Kill IT!! Deader n' Dead! #6
I do not think there is such a thing as a product/method that will permanently sterilize ground. Maybe for a year. But then grass/weed seeds will blow in and begin growing. Even if you lay down gravel. Dust blows into the cracks in the gravel - seeds land on the accumulation of dust and grow.
Sterilize - lay down your gravel - be prepared to make semi-annual trips around with a product such as RoundUp.
/ Kill IT!! Deader n' Dead! #7
It is interesting the difference in success people have with chemicals. Some chemicals if applied to heavy will fail to kill at expected as some chemicals need time to work and if applied too heavy they will basically burn and not kill. Not saying you have not applied per label, just observation.
Maybe you could find a soil PH level that would solve your issue.
The end plan is to impede growing conditions by keeping the ground dry and reducing sunlight, but yeah I still see future treatments.
I've tried different products at different rates. I've even got stuff growing in places nothing should, like the side of a concrete fixture. Ever see weeds take hold in the side of buildings or on top of metal light poles? Lots of pictures out there on the web of that kind of thing. Some seeds only need a slight amount of dust to get started.
/ Kill IT!! Deader n' Dead! #10
Maybe 10 years back when I was making home brew biodiesel, I accidentally spilled some waste vegetable fry oil on the lawn outside my shop.
Nothing has grown back on the spot in all that time.
/ Kill IT!! Deader n' Dead! #11
Last year I was looking for an alternative to Roundup and found this. It works
You can buy it by the gallon or all the way up to 275 gallon totes
2% Omri Listed Horticulture Vinegar Weed Killer
/ Kill IT!! Deader n' Dead! #12
...I want the dirt essentially sterile so that NOTHING grows. ....
That's never gonna happen. You can put seeds on sterile sand and if there's just the slightest bit of water and the temperature is correct, they'll sprout and send out roots. They'll live off of their own stored reserves for several weeks until they find a source of water. If they don't they die. If they do, they keep growing. Since most water isn't sterile, they'll suck out any nutrients in that water and keep sending roots out and down.
Products like Preen work not by preventing seeds from sprouting, but by preventing them from forming good roots. Preen is activated by water. It works, but it has to be reapplied depending on how much water the area gets and washes it away. How Preen Prevents Weeds
• Preen
So, you have to kill all existing weeds AND prevent any seeds from sprouting. Anything with root runners will infiltrate the area and work their way in from the edges. That can't be prevented.
You can put down a base, and then put in pavers tightly and that will usually deter weed seeds from finding a foothold, and makes it easier to spot-spray any that do eventually sprout up in the cracks. But nothing is permanent and everything requires preventative maintenance.
Instead of pavers, you could do stamped concrete. That's a solid surface with no path down to water. It looks like pavers, but no paths down to ground water for weeds to take hold. Then you can just power wash it once a year to remove any dirt that might accumulate in the dips.
/ Kill IT!! Deader n' Dead! #13
Helps to positively identify what you are trying to kill too. Glyphosate (aka RoundUp) is usually a major component of a broad based ground clear type product. Imazapyr (aka Arsenal) is usually the other major component.
Problem is there a a lot of weeds and grasses that are hard to kill with glyphosate. Some have become so resistant to it there is no effect on them. The imazapyr is most effective on the woody / brushy type plants and you need to be careful using it around desirable trees or bushes because it does jump from root system to roots system and it will damage or kill the desirable plant even if you don't spray it directly on.
Some common things not usually effectively controlled by a glyphosate based cocktail would be bermuda grass, yellow nutsedge, poison oak, various pigweeds, and several others. They will need a specific chemical targeted to them in order to get good results.
Hope this helps.
/ Kill IT!! Deader n' Dead! #14
Or you could just move to the moon.
/ Kill IT!! Deader n' Dead! #15
I agree with Moss Road: what you want will never happen.
Mother Nature does not like to be barefoot.
/ Kill IT!! Deader n' Dead! #16
Polymetric sand stops weeds from growing through pavers . And I stoped using mulch and put stone where I had mulch . Around house , trees, and other landscape features. About 300 tons of it:confused2:
I've heard of using vinegar before but haven't seen a product sort of made for it like the above. The vegetable oil idea is interesting, but I see side effects. At least it wouldn't contaminate like motor or hydro oil. I'll have to check on 'Polymetric sand'.
This is all related to my other thread about a shed roof/overhang and trying to get water away from the house. In the sketch below, the house is on the left, breezeway between house and garage on top, and garage on the right set at an angle to the house. The grey square is an old concrete cistern. Ground is nearly flat/level around and behind that, which leads to rainwater collecting in the blue oval area. Once I get the shed roof built, no more rain will fall on that area and the plan is to grade the 'courtyard' off towards the green line to keep rain that falls on the remaining uncovered area to drain away.
The cistern leaks a bit and at least some rainwater collects inside it, even though it's covered. That should stop once I get the water/drainage resolved. Then I can uncover it and set a grate over it for safety that will let it air out and dry. There's probably a couple of feet of water in it that will have to be pumped out. Until that happens, I'll have to watch for algae and mildew growth under the new shed roof.
Once all that is done, and the area can dry out, I can set pavers as I have funds available. But in the mean time, I don't want any plant growth anywhere in that area that can draw and emit moisture. Lack of Sun will help, but there will be enough from the open side to allow some. The end goal for the area under the new roof is to be as dry and barren as possible, desertified, moonscaped. Dry enough for the ground surface to crack and become dusty.
This all goes back to the Termite issue. I've got to get any and all water away from the house and this is a problem area that stays wet. It's been too wet to even treat with the pesticides mentioned. They would just get diluted and become useless.
/ Kill IT!! Deader n' Dead! #18
I do feel your pain...
Years ago I used to get all hot and heavy into yard work and in the Spring of the year have my home really looking good, then by July it was a tangled mess of weeds. After a few years of that, I got really tired of spending lots of time and money on yard work.
Then I got another bulldozer...oh yeah, that messed up ye ole lawn for sure.
It is to the point now where I hate mowing my lawn even. It is like being in a Nascar race, put the lawnmower on rabbit, and go fast, and go left in endless circles...oh what fun:thumbdown:, like I do not have better things to do with my time. Not that our houses are messes, and they look nice enough, but it is the bare minimum for landscaping.
/ Kill IT!! Deader n' Dead! #19
Move into town.
/ Kill IT!! Deader n' Dead! #20
Can you give me a call next time you do that? Id like to grab a poncho and a pair of goggles so I can stand back and watch :laughing:
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
JOHN DEERE 4230 TRACTOR (A64277)
JOHN DEERE 4230...
