Fit Prep Question
/ Fit Prep Question #1
mmranch
Gold Member
Crested Butte, CO
TYM T603
I am basically a welding newbie and currently configured for stick welding only. I have a question about fit before I repair something.
The backhoe on my tractor has a lock pin to keep the boom from swinging when not in use. It's made out of what looks like grade8 metal (goldish in color). It's basically a 3/4" to 1 " diameter rod, about 4" long which is welded to a smaller, long rod which is the handle of the lock pin.
I wasn't paying attention and I hadn't removed the lock pin and I swung the boom and it sheared the lock pin in two.
The break is very clean and if you put the two pieces together, the break almost disappears. When I weld this back together, I will need to grind off the outer surface of the weld to try to keep the diameter the same as the pin so it will go back in the hole.
My questions are:
1. Is it safe to weld this grade8 looking metal back together? (Hopefully no deadly gas generated?).
2. On the fit. Since I've got to grind off the protruding part of the weld afterwards... I want the weld to penetrate deep into the pin so it retains it's strength. If I were to fit the pieces together and weld it... how much penetration will I get into the pin? Would it be better to space the pieces apart about an 1/8" and weld it? Or should I grind the edges of the break then put the pieces back together, creating a small V shape gap at the outer break?
Thanks for any ideas!
/ Fit Prep Question #2
It will be tough to keep/make the pin straight after beveling heavily and welding. I'd buy a new one. Good Luck.
/ Fit Prep Question #3
The bevel will be the way to go. If the pin is really grade 8 you'll not likely get that strength back with your weld. I agree with yomax4 - buy a replacement.
/ Fit Prep Question #4
That is a lot of sideways force your hoe has. Or the pin was of some really weak material. I almost can't believe that. The pin will be even weaker if welded barring any extra hardness acquired by welding.
/ Fit Prep Question
Thanks for the ideas! I'm going to try to weld it as I always need the practice anyway. I'm also going to look at the hardware store for what kind of large pins they might have as opposed to getting the replacement from the dealer. It really only functions to help secure the boom during transport.
Thanks again.
/ Fit Prep Question #6
It's just a lock pin anyways. Mostly used for transporting. Doesn't really see any forces unless someone forgets to take it off before using the backhoe, which a common mishap.
Get you a piece of angle iron, so you can just clamp both pieces on the V of the angle iron. That way it helps you getting things aligned and actually works very well.
/ Fit Prep Question #7
You have nothing to lose by welding it but I agree with others. Just buy another piece the right diameter. It might not even be Grade 8 if it’s only for locking the boom.
/ Fit Prep Question #8
It's probably just a mild steel pin. The color you are seeing is possibly cadmium plating, but that has gone away due to toxicity issues, so it is probably just yellow zinc plating. Purely to give it some corrosion resistance. I suppose there is a chance it is hardened or maybe just case hardened to improve durability but I would still suspect just plain old steel. Will a file make a mark or just skid off it?
/ Fit Prep Question #9
Cost effective, buy new pin.....
IF you have to weld it, bevel both sides, clamp firmly in piece of angle iron to maintain alignment, weld for deep penetration and grind for clearance fit.... Get big hammer and anvil to adjust for any misalignment....
The color of the handle or loop end on any pin designates what grade material it is....
https://www.extension.purdue.edu/extmedia/ppp/ppp-94.pdf
Think this is as follows..
Black is grade 2
Red is grade 5
Blue is grade 8
Hitch Pins & Clevises
Just like bolts but uses colors instead of marks on bolt heads...
Dale
/ Fit Prep Question
Thanks for all the ideas! I got it repaired and we'll see how long it lasts (I'm sure it won't be long before it sees some force applied!).
I beveled the edges, welded it and ground off the excess. It's plenty straight but I'll see how it holds up.
Thanks again.
/ Fit Prep Question #11
Happy you at least have a temp repair. As Dave said above, that gold color is likely a thin Cadnium plating (effective but not environmentally friendly so going out of style) but you removed that during the bevel so that isn't in the equation. The issue is full penetration of the weld. If you don't 'oops' again, it might last. Always though satisfying to fix something vs. buying a new one.
/ Fit Prep Question #12
I am a pretty good welder but I would not have welded it due to time it takes to start in the center and work out, many passes with cleaning each one. I would probably have gotten a piece of cold rolled shaft right diameter and welded on a pull ring or a grade five bolt and drop in. Grade 8 is an overkill+.
Ron
/ Fit Prep Question #13
You broke a good one, just get a new hitch pin. Some things aren't worth the effort, then wonder about the integrity of the repaired part.
/ Fit Prep Question #14
I would have welded it up by beveling both sides to create a 37 degree double V bevel like this ><. Then weld a pass on each side while it is clamped in an angle iron.
It isnt truly a load bearing item (unless you forget to pull it before use) so no fear of damage if it does break.
Never buy when a repair is workable!! Now if it was a hinge pin on the backhoe, that is a different story.
/ Fit Prep Question #15
Bought my backhoe used was missing the swing lock pin. With a 7/8” bolt for a pin and scrap pile metal for handle made this. Lot of force to shear a pin that size.
/ Fit Prep Question #16
What a great idea.
I just might go shopping in my junk pile this afternoon.
/ Fit Prep Question #17
If you have a scrap pile with options to choose from, great, find an old pin or piece of cold roll or even a piece of rebar and weld a ring on it. Otherwise, weld it up. I dont buy new unless I cant find the old one and have nothing that I can use to make do. There is too much of a "toss it out and buy new" way of thinking now days. Hard times might be coming back soon so better make do as much as you can.
/ Fit Prep Question #18
Yep, that's why my scrap piles keep getting bigger.
/ Fit Prep Question #19
Ron
It is just a safety pin likely only required by OSHA since the boom isnt going to swing unless a hose breaks during transport. OP must have some strong swing cylinders to shear a 1" pin, I know my Kubota B26 sure wont.
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
2019 Chevrolet Malibu Sedan (A64557)
2019 Chevrolet...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
2019 BOBCAT T595 SKID STEER (A65053)
2019 BOBCAT T595...
2012 Ford E-350 Cargo Van (A64556)
2012 Ford E-350...
