How would you [safely] take down this tree?
   / How would you [safely] take down this tree? #31
If it was me I壇 pick that triple topped tree to domino into the top of the other shooting for about where the red circle is. Now setting up something like this need to be done correctly use a humboldt face and a full face Dutchman with an extra kicker on the stump to try and get the butt on the ground fast as well as hard for extra force.View attachment 655089
I have done stuff like this well falling timber it works but you need to be confident in your skills as well as getting out of the line of fire at the right time.
I'm sorry, but that just doesn't sound like a method I'd suggest in a situation like this for someone whose skills and experience are unknown to me. One red flag in that description: "you need to be confident in your skills as well as getting out of the line of fire at the right time." I don't mean to disrespect anyone's tree felling skills, but he fact that the OP is asking for advice in this situation is an indication that he may not be all that confident in his skills, nor in his judgement as to the appropriate time to get out of the line of fire.
   / How would you [safely] take down this tree? #32
I'm sorry, but that just doesn't sound like a method I'd suggest in a situation like this for someone whose skills and experience are unknown to me. One red flag in that description: "you need to be confident in your skills as well as getting out of the line of fire at the right time." I don't mean to disrespect anyone's tree felling skills, butt he fact that the OP is asking for advice in this situation is an indication that he may not be all that confident in his skills, nor in his judgement as to the appropriate time to get out of the line of fire.
I agree with John. I know of someone dropping a tree on a hang up and died when the second tree knocked him to the ground killing him in front of his wife, kids, and friends. He was an experienced logger, and had equipment which could have been used and he'd still be here today. Jon
   / How would you [safely] take down this tree? #33
Cut a tire and put around the base. Set it on fire and let it fall to the ground. Don't need to be near the tree at all.
   / How would you [safely] take down this tree? #34
The picture doesn't show it well, but there is probably still 6-8 inches thick of wood that is hinged to the main tree (on the left). I don't think I'll be able to simply pull it off. I think I have to cut it.
My thought was go up a ladder on the left tree, and cut it at the hinge point, so it drops down away from the tree. I don't like the idea of being on a ladder, 15 ft in the air, when everything let's go, though. A lot can go wrong quickly, including the tree potentially springing back (and bucking me off the ladder) when the split portion is cut off.
Don't do that!!!
Plenty of YouTube videos showing those accidents.
I have one of these rope saws. It works well if used properly. Don't let it get in a bind, wear heavy gloves. It's very safe since you're well out of the way. 20200513_143914.jpg
   / How would you [safely] take down this tree? #35
I recently had a widow-maker in woods that came down at a 45 angle, tangled in other trees. I one day got nerve enough to cut at the base since a large tree for protection between me and that one. All it did was slip down off trunk. I hoped wind would fell it...never did. So I went uphill cutting a big notch in it. Scary, so I'd cut a little each day, hoping wind+weight it would snap.
One day I got fed up and used three large ratchet straps, across creek to my 93 f150 farm truck hitch. 4x4, low range first (granny gear). Eased out on clutch...never touched the gas (300cu in 6). I thought it pulled loose, looked back truck was dragging that large tree. Once up on flat ground I easily safely cut it up.20200509_195830.jpg
   / How would you [safely] take down this tree? #37
Not too far but the top speed on the V417 is only 15.5 mph. Might take awhile for me to get there :D.
   / How would you [safely] take down this tree? #38
I’ve also seen this happen when using equipment, an excavator isn’t a forestry machine there’s no structure to protect the operator in the case of a limb or tree come down on the cab. Now to the falling how close you cut your pusher tree plays a huge roll in how the butt will act as well as how the face is done.
   / How would you [safely] take down this tree? #39
He may not be but it’s still a safer alternative then standing on a ladder or B pulling on a line, rope, or a chain that could snap sending a while or shrapnel at the back of him or his face. I do agree he more then likely doesn’t have the skills to do a job like this but something done from the ground is possible.
   / How would you [safely] take down this tree? #40
Since 5 years denotes that you do have some patience, you might consider cutting two rings around the tree holding up the broken section, and removing the bark between the rings. It should kill the tree and allow the broken section to be easier to remove. Keep away from it until it falls!
David from jax
No ladders is my vote!
2016 Chevy caprice (A55788)
2016 Chevy caprice...
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
2015 New Holland TS6.130 4WD 130HP Agricultural Tractor with Alamo Slope Mower (A55787)
2015 New Holland...
2019 Ford F-550 4x4 Altec AT40G 40ft Bucket Truck (A55788)
2019 Ford F-550...
2705 (A55851)
2705 (A55851)
2002 Ford F-550 Crew Cab Landscape Dump Truck (A55788)
2002 Ford F-550...
