What is cylinder liner protrusion on Y485?
/ What is cylinder liner protrusion on Y485? #1
Tim Berframe
Peace Country Alberta
Jinma 354
I have a 2007 Yangdong Y485. Head gasket will not seal. I have compression in the water. I measure the liner protrusion to be 36 thou above the deck. All liners are in plane with each other. The deck is flat. The head surface is flat.
I cannot find a spec for this engine ( Cat and Perkins and others all seem to be less than 10 thou). Perhaps one of the dealers on here might know? With such a huge protrusion, it seem doubtful to me that the skinny gasket will seal?
/ What is cylinder liner protrusion on Y485? #2
Disclaimer: I'm not a dealer.
Measure the thickness of the head gasket at the metal ring. It should be greater than the liner projection (the amount the liner projects above the block deck). If the measurement is not greater the liners may be: 1) Shimmed too high. 2) Wrong liners. 3) Liner bore not undercut enough. 4) Wrong head gasket.
I measured that wrong. The fire ring crushes on the larger ring around the outside of the liner. Those protrude about 1.5 to 2 thou above the deck. There appears to be complete crush on the fire rings for all cylinders. The soft part of the gasket appears to have crushed about 10 thou around the fire rings so I think it has sealed OK on the deck and liners. Must have leaked on the head side of gasket.
Took head to machine shop. They magnafluxed it and no cracks. It is flat with no warp. Two of the fuel injector inserts had pitting around the perimeter and they were proud of the surface by 5 thou. They flattened those and I put it together. Blew another head gasket before it came to temp. Same symptom - pressure in the coolant.
I will try to find a diesel compression gauge kit to rule out an over compression condition from the new rebuild parts. Running out of thoughts and patience...
/ What is cylinder liner protrusion on Y485? #4
Injector tube pitting is the smoking gun I believe. Aren't they copper? The fact that they project above the surface means the seal has been compromised and need to be replaced. Perhaps originally not installed correctly. Another possibility is a cracked liner if it's a wet liner engine. Very unlikely that you have too much compression - how would that happen?
Heres what it looks like. You can see the start of water pitting in the #3 & #4 cylinders. It looks worse in the photo than it is.
The injector inserts are very hard steel. Much harder than the head.
These are dry liners and brand new. They did measure identical to the old ones.
I wanted to rule out over compression because I changed pistons, liners, rods. They are supposed to be the correct replacements but wanting to rule out one thing at a time.
I just found a spec for liner protrusion. It says 0.07mm to 0.15mm (2.75 thou to 5.9 thou). Mine were 1.5 to 2 thou as best I could measure with feeler gauge. So, that would crush the soft part of gasket more and the metal part less. I think its leaking between head and metal gasket overlapping the injector insert at #3. Would shimming the liners up 2 thou make enough difference?
/ What is cylinder liner protrusion on Y485? #6
What I found peculiar in that pic is that the pitting seems to begin at #2 cylinder and grows progressively worse to #4.
/ What is cylinder liner protrusion on Y485? #7
If you don't mind my butting in; you said blew a head gasket. Where? Compression in to the coolant? Coolant into the compression chamber? Not likely, water does not compress and would bend the rod.
Itç—´ all described up the thread and in another long thread. Compression in the coolant. Not enough water to hydro lock and bend rods. I think the water is pressurized and when shut down, pressure pushes back into cylinder and takes drops with it.
I changed pistons and rods. The rods had same center to center measure so strike shouldn稚 have changed. The pistons were switched to 4 ring pistons because they were cheap and I couldn稚 buy the 3 ring set I needed. They are not identical so perhaps they displace slightly more? Just want to check
It came from factory with #3 valve lash tightened down so far that I believe I ran on three cylinders for 5 years. After changing that to spec, it ran hot with a lot of blow by for a few hours before the camshaft broke due to unrelated quality control issue. Upon disassembly, it was apparent that it was leaking between head and gasket between 3 and 4. Rebuilt last fall and gasket blew within 10 mins. Just had head ç´*ixed last week and same failure within two mins
/ What is cylinder liner protrusion on Y485? #9
Your theory has merit for sure and a tiny bit of H2O could increase the combustion also. Just my 2 cents but I believe I would be suspecting a casting flaw in an area the MagnaGlow could not be seen under that #3 valve. Exhaust
or intake?
/ What is cylinder liner protrusion on Y485? #10
Tim,
Was the top of the three ring and four ring pistons identical? Top of #1 ring land to top of piston?
/ What is cylinder liner protrusion on Y485? #11
or intake?
What little coolant would be introduced during the intake stroke would be flashed off in the flame front during combustion. If there was an increased amount you would see white exhaust smoke that dissipates quickly. I have witnessed casting flaws that will open under heat and close when cool. Rare, but not uncommon.
In the photos, I am measuring directly the old one and taking scaled measures off a photo for the new one. The old one has the smaller diameter edge that amounts to 0.718cc. That is what had me thinking the compression might be higher with the new one. With a stroke of 90mm, the 85mm new piston has a displacement of 510.45cc (ignoring the butterfly shaped cutouts on the top of piston). The old one would be 509.7cc. Seems trivial to me but I'm not a mechanic - I just play one on weekends.
So, based on your observation of the relative amount of water that has been in #4 to #1, I consulted the engine rebuilder. He loaned me some tools and my chore today is to rule out some low chance possibilities and then pinpoint location of fault:
1 Check Calibration of torque wrench
2 Do a compression check. He suggests that it should take a lot of over compression to cause gasket failure so fast (like 500psi) Little chance the small piston size diff is causing this.
3 Pressurize the water system with compressed air. Pull the glow plugs and turn over. Look for water vapor to lock down where the problem is. Pull head. Punch out the swirl chamber splice block on probable cylinder and redo magnaflux to see if casting flaw in there. OR rig up a pressure test with compressed air and try to determine a leak.
Im fearing there must be a internal crack at this point. There doesn't seem to be a replacement head for sale in China or N America.
Ill let you know how it goes...
/ What is cylinder liner protrusion on Y485? #14
blocking and sealing all the ports and bolt could be daunting challenge not mention a heavy enough section to simulate a engine block but one cylinder at a time may be more doable. My thoughts lean to water vapor not water entering the chamber my power plant experience taught me that H2O at 1000' F is no longer water (just plain old BTU's) and difficult to contain.
/ What is cylinder liner protrusion on Y485? #15
Depends on the operating pressure. Power plant boiler water is usually treated with Amerol and Amerzine, or equivalents. This tractor's coolant is probably treated with ethylene or propyline glycol. The last plant I operated was 600 psi and 750°F superheat "invisible steam". What plant runs 1,000°F superheat? A Boomer? Although there are SC and USC steam plants that run at around 3,000 psi and 1,000°F where the boiler feedwater is instantaneously flashed into a gaseous state.
/ What is cylinder liner protrusion on Y485? #16
I'm sure the torque wrench is fine, at least within 3 lbs.
Agreed. From what I see I don't believe this is the problem.
3 Pressurize the water system with compressed air. (Do not exceed radiator cap pressure, you could blow coolant pump seal) Pull the glow plugs and turn over. Look for water vapor to lock down where the problem is. Pull head. Punch out the swirl chamber splice block on probable cylinder and redo magnaflux to see if casting flaw in there. OR rig up a pressure test with compressed air and try to determine a leak.
Cat had a real problem early on with precombustion (swirl) chambers sealing. Don't rule out resealing if no cracks found. There doesn't seem to be a replacement head for sale in China or N America.
1234567890
/ What is cylinder liner protrusion on Y485? #17
Yes its Coal fire "Super heated" with 3200 PSI at the throttle valves., 750 MegaWatt units.
/ What is cylinder liner protrusion on Y485? #18
Well apparently you have not checked with us, we do have New replacement heads for the Y485T Swirl chamber in stock in Bellville,Texas. We bought up the last ones the Yangdong factory had we are the only ones that have any . They are not complete heads , you have to put valves ,seats, ect.We have all those parts too if you need them
If you want one give us call 979-865-4002
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
979-865-4002
/ What is cylinder liner protrusion on Y485? #19
I did have a Y495 that after stripping all of the engine I found that it had a block leak between the block and the sleeve.
I had to get another block and rebuild the engine.
/ What is cylinder liner protrusion on Y485? #20
try a double gasket, see what happens, I don't see complete sealing on the head to gasket interface.. you did tighten the head bolts to the proper sequence, using the proper torque, right?..
UNUSED KUBOTA BRACKETS (A62130)
UNUSED KUBOTA...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
2017 Chevrolet Express 12FT Box Van w/ Liftgate (A61568)
2017 Chevrolet...
2013 GMC Sierra 3500 Service Truck, VIN # 1GD422C84DF134632 (A61165)
2013 GMC Sierra...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
