Running machines off heating oil?
   / Running machines off heating oil? #11
I would not use HHO in a new diesel engine. Like using leaded gasoline in new cars circa 1977. Good enough for older engines, deadly for the new EPA mandated equipment. HHO has low specs so becomes the dump tank for any pipeline transitions or off spec fuel.
ULSD is not the only requirement for new diesel engines. There's cetane, lubricity, cloud point, etc. that HHO doesn't require.
   / Running machines off heating oil? #12
SAME stuff here in Ontario Canada. HHO and Dyed Diesel.
   / Running machines off heating oil? #13
It's different stuff here. It has been for over 10 years now. When I buy HHO I also get ORD. My guy has it on the same truck but the truck has two tanks. The ORD diesel tank is often switched back and forth with kerosene so they will only schedule delivery when they have ORD in the second tank. ORD and HHO are the same price so I have no clue why they would go through the extra work if it wasn't true. I asked the driver. He said that ORD has additives to keep it from gelling in the winter and to increase how well it lubricates. Neither is needed for a furnace. I don't know if it's a state law or what.
   / Running machines off heating oil? #14
The lubricity, cetane, cleanliness etc requirements are all part of the ulsd specifications. HHO has a wider spec, but all of the ulsd specifications also fall within the HHO specifications: ie its a narrow spec, within a wider band, and with some special requirements.
In a nutshell, ulsd can be marketed as HHO, since it (ulsd)is well within the HHO spec.
It doesn’t go the other way, but as a matter of convenience, cost, and safety within the distribution system, most distributors only handle one product.
As far as anti jell additives go, yes, it’s likely that some distributors may treat the delivery truck tank with additional anti jell, if they know a delivery is for vehicular use, but I doubt many do that. My distributor pulls all product from the same compartment, and, if hr treats it, it all gets treated.
Again, talk to your distributor.
   / Running machines off heating oil? #15
Living in the NE it’s the same. I believe there are 6 states where home heating oil is quite common and they require ULSD. Rest of the country is open. My state (MN) says home heating oil can be to 500 ppm. One station near me has off-highway fuel at the pump but it’s labeled 500 ppm home heating oil. Not a problem for me because another station nearby has on-highway for 15 cents less per gallon.
   / Running machines off heating oil? #16
I would think that Alaska heating oil may always be #1 instead of #2 due to the winter temps. #1 is the same as kerosene and lubricity becomes a problem in engines. Winter motor diesel down here is a blend of #2 and #1 based on area temps so varies, plus a compensating lubricant is added. As it runs toward #1 the carbon content goes down and concurrently Cetane goes down, reducing available HP. Years ago we ran industrial diesel engines on #3 to get more HP from the engines; that was the days before low sulfur requirements. Like has been said your fuel distributor should know what his product is.
A sidelight; large ocean going diesel engine ships diesels use #5 or #6 oil in those huge engines. They are both tar at ambient temps. The oil has to be heated to around 600+ degrees to get atomization. Carbon = HP and reduces the cost/HP over using #3 or #2. The Navy toyed around with adding finely pulverized coal to the Jet fuel they use in gas turbine engines to get more HP per gallon. I did not pan out for a reason I never heard.
Ron
   / Running machines off heating oil? #18
Number 1 Diesel has higher cetene than number 2 diesel. The superior autignition quality of number 1 is why it improves cold start and reduces white smoke at low temperature.
The lower pour point as an added benefit, although the lower specific gravity does cause some power loss and reduce fuel economy on a volumetric basis.
Ron
   / Running machines off heating oil? #19
That wasn't the case over all the years I lived there...
SR
Most of the population centers in Alaska have a marine climate with higher winter temperatures and lower snowfall totals than the upper Midwest.
   / Running machines off heating oil? #20
My father ran heating oil for years. When he bought his 2008 L2800 though the dealer told him not to do so. That may also have been just a CYO.
2019 KENWORTH T8 SERIES (A58214)
2019 KENWORTH T8...
Elgin Pelican Street Sweeper (A55851)
Elgin Pelican...
2025 Kivel Bale Spear Skid Steer Attachment (A55851)
2025 Kivel Bale...
202476 (A54757)
202476 (A54757)
UNUSED SDLANCH SDLL80 LOADER (A57192)
UNUSED SDLANCH...
2009 Utility Trailer Mfr. 4000DX 53ft. T/A Dry Van Trailer (A55852)
2009 Utility...
