rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,779
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
not entirely true he did follow up with some pictures of the mounted valve but he did not follow up with regards to the work done on the valve under the seat that he took apart. that was the part I was curious about. as well as if there were any ill effects or issues long term. I do appreciate what he did share and hope it does work since I'm in the process of trying it myself.
OK. I see what you mean. My assumption was that he took the sliding spool out of the PCV and rounded the porting edges. This is sort of thing that one would expect to "soften" the abrupt opening of the fluid passage. It shouldn't cause any problem.
But having said that, I can see that there are questions.... For example, exactly how did he round the edge - if that is what he did? Why did he decide on that amount? Yes, as I think about it more I think if I was doing it to my machine I'd have the same questions you do.
rScotty
