Drone suggestion
   / Drone suggestion #91
You can get accurate altitude 'lidar' sensors. They are not GPS based.
Lidar Sensors For Ground And Above Ground Imagery
The latest lidar sensors have integrated optical altimeter technology which deliver accurate distance measurements above ground level while meeting size, weight and cost requirements of UAV manufacturers.
Agriculture and forestry use lidar to inspect vegetation such as leaves and crops. Also, the above ground imagery (for example forest canopy) can be removed to view the ground surface area.
Lidar Drones For Structural Inspection
The best lidar sensors have powerful built-in signal processing, large field of view and multi-segment measurements which generate critical distance data and efficient obstacle detection, which enable safe navigation when performing structural inspections.
The below lidar sensors were designed and engineered for small UAVs. Use the web links to each lidar sensor for more information. Each of the manufacturer have excellent websites which will give you full data sheets along with the best uses for their lidar sensors.
EXAMPLE
LeddarTech Lidar Sensors
Vu8 Lidar Sensor
The LeddarTech Vu8 is a compact solid-state lidar which provides highly accurate multi-target detection over eight independent segments. Detecting targets at up to a 215 meter range and weighting only 75 grams, the Vu8 delivers nearly twice the range for half the volume compared with the Leddar M16 from which it inspires.
The Vu8 uses a fixed laser light source, which significantly increases the sensor’s robustness and cost-efficiency. The Vu8 has a high tolerance to noise and interference. This means it is unaffected by other sensors’ signal, by lighting conditions including direct sunlight, and it provides reliable detection in various weather conditions including rain and snow.
If you want to read more go HERE
My flight controller (Pixhawk) I2C port, is designed to accept these. Cost is more than the drone is worth. (For hobby uses)
   / Drone suggestion #94
FWIW...Elevations cited by digital electronic devices are derived from GPS coordinates and are interpolated from cross referenced databases...they are not necessarily accurate...
And as I mentioned earlier, it's relative to the launch point. The ridge is what put the Drone at risk. It was maintaining the 100 meter altitude based on the launch point.
   / Drone suggestion #95
Yes, both the Autel and DJI reference only the take off point as elevation zero. Anything above the takeoff location is positive, anything below is negative. They do not referee to any known tables or standards to determine height.
I dislike this due to the 400' height restriction, but if I take off in a valley and want to go up a ridge line, I have no idea of height above ground level.
   / Drone suggestion #96
Yep. Becomes extremely important to be familiar with everything around you. I've crashed twice. Both times were because I lost track of trees near me but out of my vision.
   / Drone suggestion #97
For those interested here is my homebuilt drone (with camera) that 'did' the overland tour.
   / Drone suggestion #98
I'm sure it flies well and is extremely functional but it certainly won't win any beauty contests:D
   / Drone suggestion #100
AAhhh, but it works better than a lot of commercial drones and can fly where DJI ones refuse to. That is why I have 3 the same. :)
Sakai SV540T Padfoot Compact Roller (A57453)
Sakai SV540T...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
2009 IC School Bus (A55973)
2009 IC School Bus...
1998 Homemade S/A 12x6.5ft Trailer (A56859)
1998 Homemade S/A...
1999 Dodge Ram1500 ST Ext. Cab Pickup Truck (A56858)
1999 Dodge Ram1500...
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
