Drone suggestion
/ Drone suggestion #141
It's just before sun rise. I'm setting at a build site out in the country waiting for the concrete guys to get here and pour a building pad. They'll use a pumper truck so can get some great pics and video.
/ Drone suggestion #142
Never heard of that brand. Anxious to hear a report from you. And see some pics of the drone itself. Thanks for updating us.
Here is a link for your interest. Cheers. Let me know if that doesn't work. (Link deleted)
The 2020 is the latest version of the X8 SE.
Fimi X8 SE 2020
/ Drone suggestion #143
Won't open. But when I'm home on the laptop I'll use the info to find it. Thanks!!!
/ Drone suggestion #145
What type of wireless technology do these things use to stream first-person video over such long distances? Or even send/receive the transmitter controls?
Rob
/ Drone suggestion #146
My Mavic Air uses
The Mavic Air uses enhanced WiFi to communicate with the controller, essentially a high-power WiFi transmitter in the controller and a redesigned omnidirectional antenna in the landing gear of the Mavic Air. ... These communication protocols are much less prone to interference than Enhanced WiFi
So basically its not like the wifi you use in your home...technically its RF used between 2.4ghz and 5 ghz(like RC users). Some drones use GPS like the DJI Phantoms.
My Mavic Air can use GPS I am told which will give me he 2 mile range but...........I am only supposed to keep it within visual. Also I am scared of losing the drone way out there lol.
DJI Wi-Fi
DJI utilises a Wi-Fi transmission system on its beginner and consumer drones as a cost-effective method of control. The drone uses its own private Wi-Fi that the user connects to using a password.
DJI’s Wi-Fi allows users to control their dedicated remote controller or a mobile device, however, this will usually (VLOS) result in a reduced range.
DJI Drones Using Wi-Fi: DJI Spark and Mavic Air.
Dual frequency bands of 2.4 and 5.8 GHz are available with Wi-Fi, automatically switching for maximum control.
Two forms of W-Fi are currently used by DJI; standard Wi-Fi with the Spark and enhanced with the Mavic Air. The standard Wi-Fi gives the Spark a North American transmission range of up to 1640ft\500m and the enhanced Wi-Fi gives the Mavic Air a transmission range of 6561ft\2000m. These transmission ranges allow users to maintain VLOS (Visual Line of Site) with their drone, one of the US regulations.
Both Wi-Fi systems provide a video transmission in 720p to the connected mobile device. This allows a clear view from the drone’s camera for control and shot setup etc.
/ Drone suggestion #147
Hi powered WIFI.
/ Drone suggestion #148
High powered WiFi can communicate for 8km? Wow. I'll have to read up on that.
/ Drone suggestion #149
My EVO will do 7 miles line of sight with no obstacles. So will Richards. 7 miles horizontally and 2900 foot ceiling, neither of which I'm interested in anyway, FAA rules for drones, professional and otherwise without a special waiver is... 400 foot ceiling and LOS only (Line of sight). To me that equates to 1/2 mile tops and I will adhere to the 400 foot ceiling as well. The reason I did not buy a DJI product is all DJI drones (with the exception of the Tello ((which I also have)) all have geofencing built into them and I don't need nor want to be unable to fly where I want to. There a ton of small airstrips out this and everyone is considered restricted airspace. Don't matter if no aircraft have landed or taken off there in years, they are registered airports and as such are in the DJI database as restricted.
Have more than enough 'Big Brother' stuff to deal with. Not paying big bucks for any drone that comes with built in restrictions. The EVO has none, why I have one.
MY EVO flies Wifi dual band and Bluetooth depending on the terrain and conditions. My Tello flies Wifi only.
/ Drone suggestion #150
That must be Bluetooth class 5? Because most other BT classes have a range that is typically less than about 50' without severe degradation.
Rob
/ Drone suggestion #151
My home-made drones use WiFi or 915 mHz. I normally stick with WiFi which has a range of max 700 meters. However once programmed there is no need for a WiFi link unless I want to watch its' progress on a map.
The Fimi Drone uses 5 gHz frequency.
/ Drone suggestion #154
The line of sight issue is vague. My interpretation of FAA'S guidance is not thing between you and the drone. Not how far you can see it.
I fly beyond my ability to physically see the drone a lot. My autel is large compared to today's foldable models and it's hugger orange. I can physically see it much, much farther thand dull colored compact drones.
I will once in awhile go beyond the 400ft elevation limit but not very often. Most of my flights are videoing or taking pics of ground objects. Not much sense in going beyond 400ft.
/ Drone suggestion #155
I stay under the 400ft... never a reason to go above it for any practical reason and I surely don't want to put anyone in harm's way. We have a fair number of pleasure aircraft, coast guard and army helicopters that frequent our area and they fly low. On line of sight, my interpretation is the same as Richard's. I frequently lose sight of mine and use the GPS map screen to know where 'I' am at.
/ Drone suggestion #156
I fly beyond my ability to physically see the drone a lot. My autel is large compared to today's foldable models and it's KUBOTA orange. I can physically see it much, much farther thand dull colored compact drones.
Fixed it for you Richard. I read it as line of visual sight not what you see on the camera....and 400 feet maximum altitude ceiling is based on the take off point, not the surrounding topography so in essence you could take off and climb to 400 feet, fly over a canyon and be at 1000 feet.
FPV don't count as I read the rules.
/ Drone suggestion #158
Parrot's are done. Their maker is pulling the plug on all consumer drones. All they will make is drones for LE.
/ Drone suggestion #159
Yes I saw that. Dustin Dunhill did a few vids on Youtube using Parrot drones. He converted one to use 4G and flew from one Hawaii Island to another and back with beautiful clear footage all the way. Next time he tried it his drone disappeared. His vids are worth watching. Below is his inter-island flight with 4G. It's a long video but very interesting.
As for the Fimi I ordered, it has a fence set at 500 meters height. I would never even think of going that high. Too many aircraft and emergency helicopters fly over my area. Before they scrapped the F111s from our local AFB, I had a F111 fly around my house not much above tree height, or so it seemed. I could clearly see the pilots helmet as he flew by.
Parrot DISCO Unlimited Range! 4G LTE + Li-Ion Mod - 25 Mile MAUI to LANAI Manual Flight 😱😍 - YouTube
2017 Mercury SeaPro Outboard Boat Motor (A61574)
2017 Mercury...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
LOT OF METAL GATES (A63291)
LOT OF METAL GATES...
Volvo EC220EL (A60462)
2007 Toyota RAV4 SUV (A61574)
2007 Toyota RAV4...
Mounting Plate Skid Steer Attachment (A61572)
Mounting Plate...
