Demolish burnt house
/ Demolish burnt house #1
DaKing
Member
Chaparral
Shovel and Hector
My home burned down, lost everything.
Insurance is giving me $XXXX.XX to go towards demolishing and removal. I'm thinking of using that money towards a tractor, as I've been wanting one for awhile. I own a few different plots of land across the state, so it will get use.
The roof of the house is still up on 3/4 of the house. The whole inside is burned dust. I have a dump trailer, or I can rent large dump containers to take the stuff off land.
I'm looking a compact tractors with front loader and a back hoe. Anyone use something like that to bring down a structure? I MAY hire someone with a larger tractor to bring the house down first...
I'm looking at B2650 or something near that from other vendors. I want the tractor to fit in my dump trailer. Although I do have a few other larger trailers if I go bigger.
Thanks.
/ Demolish burnt house #2
NAILS = flat tires .........
/ Demolish burnt house #3
I don’t recommend. Rubber tracks aren’t a lot better. They’re bad to cut. You need a metal tracked trackhoe. Even with the flat tire aside you’ll need a lot bigger boom than a tractor backhoe has to safely tear down a house.
/ Demolish burnt house #4
One story or two???
Don't hire a "Restore" type company - I wish I did the work myself.... I could have saved the insurance company and myself a ton of time, money and headaches....
/ Demolish burnt house #5
The neighbor has taken down houses and larger buildings and he uses a trackhoe. Depending on the age and dust, he sometimes uses a water sprayer. Some of that stuff you don't want to be breathing.
/ Demolish burnt house #6
Before you start demo, check with your local landfill. Some agencies will not accept burn out material because it contains hazardous material. If so, then it has to go to a special hazardous material dump and the costs will double or triple. If you already accepted an insurance payment you may be SOL.
/ Demolish burnt house #7
You can't sell burnt copper wire these days (EPA) BUT a friend got a letter from the Fire Marshal about origin and was aloud to sell it.
Some insurance companies frown on DIY repairs/removal be sure to check first.
/ Demolish burnt house #8
^^ Yeah, that.
Hire someone to do the demo. You want a large excavator with a "thumb". Around here, that's about $1000 a day. Roll-off dumpsters to haul away the debris. Those are about $300 each, including disposal in a construction debris landfill.
Couple of years ago, a buddy of mine got a turn-key quote to demo a 1600 sq. ft. house. It was $6000, to tear it down and haul it away, including the concrete slab. Hope that gives you some idea of what you're looking at.
/ Demolish burnt house #10
That type of job is hard on equipment for sure.
/ Demolish burnt house #11
Thanks.
Sorry for your loss! Glad you had insurance. I hope they treated you right. I second what everyone has said already.
Additionally:
Are you inside a city or in an unregulated area? Are you planning to rebuild on the same site?
We had a structure that was badly deteriorated and suffered some wind damage. It needed to be cleaned up. We set it on fire and burned it. Dug a hole next to it with an excavator, pushed everything into the hole and covered it up. That was several years ago and you can’t tell there was ever a structure there now. We did not have a slab to deal with.
/ Demolish burnt house #12
^^ Yeah, that.
The ONLY tool for your job is an excavator with a thumb!
/ Demolish burnt house #15
Before retirement I was a Facilities Manager for a school district. We demoed a number of schools to build totally new schools on the site. Our demo contractor hired an operator from Idaho who they would fly in and put him up for the duration of the demo. They provided him with a large track excavator with thumb. Due to state requirements, 85% of the material had to be recycled. This required that each type of material, steel, wood, drywall, electrical had to go into different piles. This guy was so skilled that he could pick a single piece of sheet metal flashing from the building and put it in a separate pile as he worked. I watched him one day pull a steel beam out of the structure, but it had a wood nailer attached to it. He swung the beam against a concrete wall and popped the wood right off the beam without anyone having to touch it. I have a video somewhere and if I can find it I will post.
/ Demolish burnt house #16
My town is pretty busy tearing down small old houses and putting up 5000 ft2 mansions. All done with track hoe and thumb, about $3k for 1000 ft2 homes, one story homes build around 1953. They put up a heck of a good fight, granted they are in good shape and not burned out.
/ Demolish burnt house #17
If it is new enough to be pine construction you might get it with some time using a small setup. If it is older and built with pinned beams
and hardwood lumber two story I dont think you will get it. I have taken down 3 barns and 2 houses in my life, all pinned and sometimes
you just dont see how they can still be standing after you rip out everything you thought was holding them up. But all we had was a couple
18-20 thousand pound 45 horse backhoes. Good luck, be carefull, and have fun.
2016 Bobcat E42 (A64126)
2016 Bobcat E42...
Grain-O-Vator Corn Sileage / Grain Feed Wagon (A66408)
Grain-O-Vator Corn...
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
2007 VIKING TRIPLE AXLE TRAILER (A65643)
2007 VIKING TRIPLE...
(4) 25x10-12 4 Wheeler Tires w/Rims (A64127)
(4) 25x10-12 4...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65583)
IMPORTANT PLEASE...
