Kubota L2201
/ Kubota L2201 #1
taylorblake
NE Alabama
Nothing Yet
Found a local listing for a Kubota L2201 with a bushhog for $2700. Owner hasn't gotten back to me on the hours on it yet. Thoughts on this price?
/ Kubota L2201 #2
Kubota L2201
1975 - 1978
Compact Utility tractor
Series next: Kubota L2601
Series back: Kubota L1801
Manufacturer: Kubota
Factory: Japan
Variants:
L2201: 2WD
L2201DT: 4WD
Kubota L2201 Engine:
Kubota 1.1L 3-cyl diesel
Kubota L2201 Power:
Engine: 22 hp [16.4 kW]
Power Take-off (PTO):
Rear RPM: 540/860/1000 (1.375)
Transmission:
Type: unsynchronized gear
Gears: 8 forward and 2 reverse
Dimensions:
Weight: 1830 lbs [830 kg]
Wheelbase: 63 inches [160 cm]
Length: 106 inches [269 cm]
Width: 66.5 inches [168 cm]
Height: 54.7 inches [138 cm]
Front tread: 37.8 to 51.6 inches
[96 to 131 cm]
Rear tread: 41.1 to 55.7 inches
[104 to 141 cm]
Mechanical:
Chassis: 4x2 2WD
4x4 MFWD 4WD
Steering: manual
Cab: Open operator station.
Page information:
Last update: January 12, 2018
Copyright: Copyright 2018 TractorData LLC
Contact: Peter@TractorData.com
/ Kubota L2201 #3
I'm in the process of finishing a tiny house on a piece of property that's roughly 9 flat acres.
It was bush hogged last year so there's some growth, but shouldn't be any trees larger than an inch or so in diameter. I would like to have a small garden to feed me and my family. In the future a one acre market garden.
So here's my question: Should I go with a subcompact package deal from a dealership or try and search around for a used model?
I've noticed used models are hard to find with a FEL and I would need to buy some implements separately (cheaper with a package?)
Caution on this potential L2201 tractor purchase.
You are researching a forty (40) year old tractor that was in production only three years. You may be considering the one unit of this model still operating in Alabama.
Spare parts will probably be zero.
No Loader. Probably only 2-WD meaning OK for mowing but low traction for garden tasks, such as hilling.
Manual steeting. May be OK for you on a light tractor, not for me at age 72.
Traditional clutch and gear transmission. Do you have experience operating same? PTO probably coupled directly to tractor engine.
Determine if you can remove mower PTO shaft from tractor. Tractor and mower may have been joined for fifteen years and the union immovable.
How are the tires?
How proficient are you as a mechanic? Do you have metric tools?
Found a local listing for a Kubota L2201 with a bushhog for $2700. Thoughts on this price?
$500 strictly as a learner and kitchen garden tractor. L2201 should operate a 48" light duty garden PTO-powered, forward rotation, Roto-Tiller admirably. Would pull a trailer well.
/ Kubota L2201 #4
Is it grey market? Can you get parts from the Kubota dealer? How many hours on the clock? I just sold a Misubishi D2350 - very similar to that tractor and definitely grey market. It had a front loader but no mower. It had about 2200 hours and had been well maintained. Everything worked, almost new tires. Buyer offered $3900. I accepted.
Sakai SW354 (A60462)
2021 CATERPILLAR 303.5E2CR EXCAVATOR (A62129)
2021 CATERPILLAR...
JOHN DEERE 4955 TRACTOR (A62130)
JOHN DEERE 4955...
2018 Volvo VNL 760 T/A Sleeper Cab Truck Tractor (A61568)
2018 Volvo VNL 760...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
2010 Ford F-150 Pickup Truck, VIN # 1FTEX1CW9AFC54781 (A61165)
2010 Ford F-150...
