Rotary Cutter Solution for Heavy/Dense Brush with 34 hp PTO tractor?
   / Solution for Heavy/Dense Brush with 34 hp PTO tractor? #51
Ok yes that works great! And a hydraulic top link seems quite useful. I wish I could find a rotary mower in good condition like yours for $700. What is the width of your mower? Do you know what was the recommended PTO power for it? The used equipment I see for sale in my area is really beaten up. A new Woods cutter that is sturdy enough for the job like the BB60.50 is about $4,500 CAD. It is not $13,000, but I prefer $700 :p
The only drawback with this kind of equipment is that the roots stay there and I would still need to deal with the roots, especially if I want to grow something else. I was wondering how a rotary mower would compare to using the scarifiers of a box blade (tilted using a hydraulic top link) to pull the brush by its roots. It would be nice if a box blade worked well, since these are very versatile attachments.
Mine was $700 brand new and delivered to my door. The seller even wanted to trim the PTO shaft for me but it was already late and dark for that. It's a 1.2m/47" cutting width (1.3m/51" outside) and it a light to medium duty series.
Now that I know what the tractor is capable, I could go up to 1.3m/51" cutting width or even 1.3m/55", costing $750 and $800 respectively. Recommended HP for this mower is 25 to 40HP I believe. The same 47" mower but a top brand would cost me around $900.
There are the forestry versions at a much much higher prices and much heavier duty as well.
Most spindles come with 2 chains with the option to run 4. I've never tried 4 sets of chain though. A few manufactures will also offer a 3 chain spindle.
I suppose one could modify on of your style mowers to run chains. It's just a piece of chain and a connecting link. Always use grade 80 or superior chain.
Thanks. It looks well designed, with what looks like replaceable skids, bracing and the back seems quite sturdy as well. I assume it is from an European manufacturer?
   / Solution for Heavy/Dense Brush with 34 hp PTO tractor? #53
Yes. This actually a Portuguese manufacturer. We have quite a lot of them making these things for kinds of budgets.
These are built to take a beating. I mean, we back these things against everything and it just takes it.
The skids are adjustable in height, usually in 3 steps. There is a hydraulic side shift option available as well.
The forestry versions are even more sturdier and heavier duty with the option of a hydraulic gate in the back.
Here is a brochure I found in English from Joper, one of the best manufacturers here: http://joper.com.pt/attachments/upload/Catálogos/ctlg_cortamatos_joper.pdf
I like this one a lot because the skids are curved and doesn't tend to drag brush in front of it or leaving a mark on the ground.
Thanks. I wish we had good equipment like that available at this price point in Canada...
   / Solution for Heavy/Dense Brush with 34 hp PTO tractor? #55
Looks like the Portuguese version of EA!
   / Solution for Heavy/Dense Brush with 34 hp PTO tractor? #56
I wish U.S. manufacturers could start building something like this!
E.A., Land Pride, Bush Hog, Woods, et al...are you listening?
I had looked at EA's box blades and they seem quite nice. Their rotary cutters are not as nice though (10 Ga deck). It seems to compare to offerings from Land Pride and Bush Hog.
   / Solution for Heavy/Dense Brush with 34 hp PTO tractor? #58
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A57024)
Greenworks...
2017 FORD F-550(INOPERABLE) (A55745)
2017 FORD...
