Landscape Rake / Box Blade Gauge Wheel
/ Landscape Rake / Box Blade Gauge Wheel #1
Hilbilly
Barriere, BC
Kubota Grand L6060HSTCC
I've wanted a gauge wheel for the box blade for a while and finally got around to putting one together. I had the solid wheel and A frame left over from my front mount brush hog project and figured it would make a perfect gauge wheel. All I had to do was figure out how to set up a mount on the box blade and the landscape rake, that would allow me to use it on both. Finally got it done and I have to say this makes using those implements SO MUCH better. Very happy with how much easier it is to fine tune the amount of material I want to move plus I can leave the 3PTH in float and set the wheel height to just scrape in the low spots and then it will cut the high spots down. Much better for cutting the highs and pulling them into the lows. The difference is amazing. Especially having the top and tilt now.
/ Landscape Rake / Box Blade Gauge Wheel #2
Yes, I agree 100 percent! Have gauge wheels on my box blade and rake also. They double the usefulness of the tools, in my opinion.
The 3PH float lets the tractor go over humps and thru dips while the blade stays level.
/ Landscape Rake / Box Blade Gauge Wheel #6
That's pretty sweet looking.
The only drawback to gauge wheels is it usually makes reversing the rake or blade impossible.
I cut the tubes for my gauge wheels on my rake to add extensions and was planning one day to add receivers to my grader blade. The original spacing on the wheels had them too close to the rake for my liking.
I wasn't sure about the spacing of the wheel and thought it might be too close to the rake / box blade but after using it for a while I think the spacing is fine. More use will tell for sure.
With this setup I can spin the landscape rake around and use it in the reverse position. The mount for the wheel is attached to the main frame and sits above the actual rake assembly. Of course I could always lift the wheel and travel in reverse.:)
/ Landscape Rake / Box Blade Gauge Wheel #8
Yeah your rake is a much better design and stronger than mine. Nice setup!
2008 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2014 Chevrolet Tahoe SUV (A64557)
2014 Chevrolet...
2009 FORD CROWN VICTORIA CAR (A66091)
2009 FORD CROWN...
2021 PETERBILT 367 (A67714)
2021 PETERBILT 367...
More info coming soon (A64557)
More info coming...
