2005 Toolcat rear leaf springs worn out???
   / 2005 Toolcat rear leaf springs worn out??? #1
699skidoo
Bobcat Toolcat
Hey guys
Wondering if there is supposed to be an air gap under the rubber stopper when the dump bed is not loaded? Mine are touching and I'm wondering if the leaf springs are worn out and need replacement? Is there a spec somewhere? On a similar note anyone have a hardcopy of a service manual for a 2005 toolcat?
Thanks for the help.
   / 2005 Toolcat rear leaf springs worn out??? #2
The newer Toolcats don't have solid axles or leaf springs, but they do rely on rubber snubbers for part of the suspension. I looked at my unloaded G series and it is also sitting on the snubbers on all 4 corners. I hope you get some answers. :)
   / 2005 Toolcat rear leaf springs worn out??? #4
the 2005 series A had the rubber touching the axle and no air gap
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
66" Grapple (A53316)
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2023 Load Trail Tri-Axle 10 Ton Gooseneck Flatbed Equipment Trailer (A55788)
2023 Load Trail...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
