I have a ford 4610 with the deluxe rear remotes and auxiliary engine mounted hydraulic pump. I currently have my loader plumbed into the rear remotes but looking to upgrade the loader controls to a more forward mount (joystick or twin stick TBD) and free up the rear remotes to use with a top and tilt setup.
This is the plate mounted currently running from the engine mounted pump and to the rear remotes
Options i've thought of. Please pick apart or let me know if there are better ones i'm missing
1) Remove the output of the plate, run it to a open center valve for the loader with a PB port, run the output of the PB port back to the line running to the rear remotes. I believe this would give priority flow to the loader but when the loader is not actuated the rear remotes would still get full flow.
2) Use an electrically actuated port multiplier ( I don't really like this option as it gets pricey quick and still doesn't give me forward controls)
3) Tie down one rear remote, and run the open center valve off of it and use the other rear remote for a hydraulic top link. When i wanted to use the loader I would have to click the first remote down to be always 'on'
Any other thoughts? I think #1 is my best option, and not 100% sure if #3 would work.
