Blew Hydraulic hose on FEL, instant drop.
   / Blew Hydraulic hose on FEL, instant drop. #1
cqaigy2
Super Member
West Cascades, Washington State USA
PT 422
Just a reminder for all of us.
Finished up with the rough-cut mower. Took tractor it into the shop for lubeing and inspection. My rough-cut mounts on my FEL so i can raise it a ways up in the air if i want and i had it up in the air to inspect the underside. Just as i was reaching in to prop a 4x4 under it, a hose blew and it dropped like a ton of bricks, as in instantly. Dropped from full height and hit the ground with a bang. I'm fortunate, as all i have is a small blood blister on my wrist, from the edge of the mower deck and a little sore to the back of my hand.
Normal raise it up prop a 4x4 under it, than chain it up, to the overhead beam.
Im kinda a belt and suspenders kind of person, maybe because my belt isn't hold my trousers as well as it used and my belly is pushing them down. :laughing:
   / Blew Hydraulic hose on FEL, instant drop. #2
   / Blew Hydraulic hose on FEL, instant drop. #3
Some machines are made with what company I worked for called a "holding" valve in the cylinder. It was design to hold in such a failure. Sort of interesting they are not on FEL to me. Maybe some do but the JD and Kubota I have don't. If a machine is made to lift loads such as a crane or excavator the ones I have operated had those valves. Have wondered why fel don't.
   / Blew Hydraulic hose on FEL, instant drop. #4
The solution to prevent the FEL to drop down when a hose fails is a Double pilot check valve. One per cylinder basically. The reason they are not used in tractors is because it disables the float function.
   / Blew Hydraulic hose on FEL, instant drop. #5
All man-lifts have to be certified by OSHA in USA. I am sure the tractor industry finds EPA attention a sufficient burden.
   / Blew Hydraulic hose on FEL, instant drop. #6
Yep, man lifts and forklifts have have a hydraulic fuse valve mounted to the base of the cylinder to block flow if it is over a certain amount of gallons per minute.
Aaron Z
   / Blew Hydraulic hose on FEL, instant drop. #7
   / Blew Hydraulic hose on FEL, instant drop. #8
Glad it missed you.
I need to raise my loader bucket (around 1,500 lbs if I recall) not so much because I need the bucket in the air but rather, I need the lift arms out of the way while I work on the engine (replace steering pump). Working in there with the bucket lifted is nothing more than a guillitine pinch point that scares the dickens out of me so, I have a fairly large boulder at the base of my driveway. When I need bucket safely lifted in the air, I simply go down to the big rock and set it on top of the rock so now it's totally supported while I do my stuff.
When I drive by someplace and see they have their loader bucket lifted a mile in the air while the machine is PARKED (it will be there for days) I just scratch my head with wonder.... what on earth are they thinking, leaving their tractor or backhoe parked there with the loader bucket lifted so high. Strikes me as 100% stupid.
   / Blew Hydraulic hose on FEL, instant drop. #9
Most industrial loaders that can't be removed now have a lift support bar that can be propped up to brace the loader arms. I like the ones that slip over the lift piston rod.
OP - glad you didn't get caught too badly.
   / Blew Hydraulic hose on FEL, instant drop. #10
How is relying on a hydraulic hose different than relying on your truck’s brake lines?
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
2023 Club Car Carryall 700 Utility Cart (A54811)
2023 Club Car...
GROUND PROTECTION PAD 8X4 15 COUNT (A55745)
GROUND PROTECTION...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
MISC CHAINS (A55745)
