Source for Kioti Branded 3rd function?
/ Source for Kioti Branded 3rd function?
Here is the one that a couple of us did a few years back on our ck35's imagine it would be the same for your 3510.
My Pictures start on post 21 did all hard lines on mine!
https://www.tractorbynet.com/forums...35-3rd-function.html?highlight=sinatra+method
Did you use the valve listed in the "sinatra method" or something else?
How's that function?
For some resin I am getting stuck on the valve type. I think I've found a few options looking at other kits that are out there, and can be into a valve and base for under $200.
But when you start swing kits for $450 (bailey) or hopefully a kioti with hoses for $650....
/ Source for Kioti Branded 3rd function? #22
Just so you're aware, I'm not sure the Kioti brand is a "true" third function. I lose curl/dump when I open/close my grapple, so I'm thinking it's a diverter style. But...my experience with tractors isn't all that much, so I could be mistaken. I verified everything is installed correctly, because my thinking was that I shouldn't have lost curl/dump with a true third function. But whatever. I've learned to work around it.
FYI, just bought a Kubota and had THE Kubota third function installed. Was told would be able to operate it with the other fel functions, well now we realize it will not lift when the 3rd function is being used. Have been told that was true of those type of systems but dealer's sales person last told me he will check on it for he was told they (3rd functions) should be able to be used with the fel functions.
/ Source for Kioti Branded 3rd function? #23
Yup. I wasn't a fan. That's why others have modified the existing handle to add buttons and such. You get used to it after a while.
Not a fan of it either really. The nice handle it has(d) to begin with (the JD style) is much more comfortable. Really not sure why they could not put the open/close buttons the same place JD does and operate it with your thumb instead of first (2) fingers.
You do get used to it however. Still a PITA to switch between my tractor and the old mans.
/ Source for Kioti Branded 3rd function? #24
I agree. Especially with the NX model. They tout the ergonomic handle in all their literature and then if you want a third function they remove it and put on a basic knob? That's unacceptable.
What workarounds are possible? Justman mentions modifying the existing handle which I would be interested in. Or is it possible that the John Deere kit would work (not sure how similar the handles are)? Just looking for a way to keep my handle and have thumb operated buttons like you said.
Kioti's loaders are impressive and they tout that as a selling point as they should, but things like this and their crappy valve that eliminates the ability to do two functions at once (practically, anyway) kind of take some of the shine off of it. As someone considering buying a Kioti it's definitely not a deal breaker, but it is an oversight on their part.
/ Source for Kioti Branded 3rd function? #25
I'm reasonably sure some creative person with a bit of time on their hands could move the buttons from the ugly stick to the ergonomic stick...and then show us all how to do it!
I found it to be more of a "want" thing than a "need" thing though. I liked the ergonomic handle because it looked cool. That being said, I came from a JD2305, and the handle was a little black knob thing. The ugly stick with buttons is still better than what I had, and it works just fine.
/ Source for Kioti Branded 3rd function? #26
You nailed my thoughts exactly. Handle is nice, it痴 great, and I hate that I would have to get rid of it. I feel like shouldn稚 have to... But the overall effect on production is zero.
/ Source for Kioti Branded 3rd function? #27
Used this valve and sub plate, looks like valve is no loner available. Might be able to find it on ebay. Valve works very good no issues and opens and closes the grapple quickly. Just make sure what ever valve you pick is open center.
1 Station D?3 Subplate Open Center | Subplates | Hydraulic Adapters & Fittings | Hydraulics | www.surpluscenter.com
12 Volt DC 21 GPM Argo RPE3-?6 DA Hydraulic DO3 Solenoid Valve | Solenoid Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
Here is the handle I used Absolutely love the ergonomics, very easy to operate the 2 buttons with my thumb.
Universal Handles - AU Series
Thanks man!
Where'd you buy the Handle? So far this is one of the more costly parts!
Also, hows the speed on the actuation, is it super fast and jerky?
I'm reading this morning and now back to considering a diverter valve. While it can't do lift/curl/close at the same time, feathering the grapple close could be useful.
/ Source for Kioti Branded 3rd function? #29
I decided that I refuse to pay my local Kioto dealer $1200.00 for a 3rd function setup for my tractor. I have two options to consider. The 1st is to buy two hoses to connect onto my rear remote and make the needed brackets to mount the hoses on my FEL. The second option would be to buy the parts and make my own.
/ Source for Kioti Branded 3rd function? #30
You should be able to buy a small rocker switch and install it in your handle. That is what I am going to try and do. I hate the Kioti 3rd function handle.
/ Source for Kioti Branded 3rd function? #32
Bought it from a local hyd distributor here in my area many places carry them.
Speed works fine i can open entirely in about 3 seconds no jerkyness
Never needed to feather a grapple lid you either want it open or clamped tight.
I appreciate all the responses...but did anyone read my OP?
I know all about the 3rd party options.
Was asking for a Kioti branded one.
/ Source for Kioti Branded 3rd function? #35
I decided to go the cheap route using the rear remotes. I bought my hoses from Discount Hydraulics and the fittings from Surplus Center. Total out of pocket was around $250.00. I don't see me using this very often and decided to spend the extra money towards attachments. I bought a stump grappel bucket and a 72" Skid Pro rock bucket. I made a bracket to attach onto the loader hydraulic disconnect bracket. My 3rd function disconnects will go there. Eventually I will make a front bracket for the grapple disconnects on the loader crossbar. I'm waiting for two reducers to come in this week for the grapple bucket hoses.
/ Source for Kioti Branded 3rd function? #36
Not looking for a diverter.
I am looking for the factory Kioti 3rd function kit.
The price for the NX series is $1250.00 for the kit and the new handle is just a round knob
/ Source for Kioti Branded 3rd function? #37
Loader disconnect bracket.
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63118)
2023 Kubota Z412KW...
John Deere 5525 (A60462)
John Deere 5525...
Year: 2006 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 103892 miles Plate: Body (A61568)
Year: 2006 Make...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A60352)
2019 Allmand...
