Box Scraper 5’ box blade recommendations
   / 5’ box blade recommendations
So Rhino is a good (quality) implement... I'm assuming that is the price "New" (which you could still do better on), if that is used I don't think it a good deal... new maybe ok.... It looks like the Rhino CBX60 only weights 280lbs so that shouldn't be an issue
My only other caution is if I read your tractor specs right it is 57.1" wide so a 60" blade barely covers your tires track.... depending on a couple of things you way want to look wider... not sure the width of your driveway / roads you will maintain or the pitch, or crown but I have a 72" box blade on our 40 HP machine which is 68+" wide & I wish I had gone wider. The reason is in many areas where I have either drainage or culverts I can not get the box blade as close to the edge of the culverts as I need to (especially when I add some pitch to the blade).... just food for thought... you may want something a little wider
Also it is a box blade so you may want to look for a used one... no movable parts & not a lot of wearable parts so it is pretty easy to spot an abused one...
That is some solid advice! Thank you! I was thinking that my machine only having 25hp would be better of with something smaller but if I angle it, I wont cover my tracks. Besides, I am getting 3” spacers on each side because I am on hills. Going to look for a used 6’ to start with. Price goes up fairly high at that size for new ones.
You do not have a location listed in your profile.
If you did, it likely would be possible to recommend other (more cost effective) choices local to you.
Sorry. Newbie here. I just updated my profile. Thanks!
Man, there are some great advice here. I really appreciate it. Thank you all! I am hoping to use it to do some leveling work and maintain a gravel road. Possibly use it to push snow too. I imagine I will leave the backhoe on most of the time other than winter when the box blade will be on.
   / 5’ box blade recommendations #14
You generally do NOT angle a box blade (other than front to back, or side to side, tilt) so if it just covers your tracks and maybe a couple inches more on each side, that's all you need... Steve
Thanks Steve! I was thinking back blade. I am very ignorant at this point. I grew up in the city and know little of the tractor world. That is why I am here to learn. Other than the loader and backhoe, I am just exploring attachments I will need. Thought this would be a good one to start with. I did order a piranha bucket blade.
   / 5’ box blade recommendations #16
I would say that a 6' box blade is a bit much for a 25HP tractor.
   / 5’ box blade recommendations #17
Re: 5 box blade recommendations
The "C" designation means the box blade is made for compact tractors...Tractor manuals usually have recommended attachment sizes etc...
   / 5’ box blade recommendations #18
I agree with fried1765, a 6 footer will be a lot for your 1720. If you are just scraping the top layer of loose gravel or soft soil, you would probably get away with it. For what you describe, a heavier 5 footer would do you better. I have a 25 horse compact tractor, I can get it to spin tires when I get a 5 footer loaded up. Better to do a couple more passes than be frustrated not being able to pull it.
Thanks for the advance! IMG_3129.JPGIMG_3131.JPG this is what need to maintain. Would a box blade be the right implement for this? Should I consider a back blade or rake? I have other uses for a box blade so if that will work, all the better.
   / 5’ box blade recommendations #20
This sounds more like a traction issue...I can pull a 60" bb over flowing with wet crusher run up hill with just a 17HP b series with no issues...the only time I lose traction is when a scarifier hooks on a huge rock or big root...which the same thing will happen with much heavier and more powerful machines...
Again, what does the manufacturer recommend ??
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
20ft Jumper Cables (A57454)
20ft Jumper Cables...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
Troy Built Weedeater (A57454)
Troy Built...
