Generator question
/ Generator question #21
My little Honda inverter generator will run my microwave, no problem at all...
SR
/ Generator question #22
Bought a neat little gadget a few years ago, called Kill a Watt. Plug it in, gives volts, current, Hz. More features that I never used.
/ Generator question #23
Those are great for checking basic power quality stuff like this. Mostly designed to check power usage, but the frequency, voltage & PCF meters are super handy for checking generators. They make power strips as well, but those are missing some of the quality functions i believe.
/ Generator question #24
I finally decided to check the outlet voltage on my 20 year old 7000w Generac generator this past weekend while in middle of all day use. I knew it wasn't and never did put out 120v because it wouldn't run my microwave, toaster and coffee makers always took longer, I put the volt meter on outlet at the the generator and in house, the readings was 114-115 volts.
So I guess this summer it's time to update it to something that will put out 120 volts, on the assumption that they do make generators that does put out 120 volts, 119 probably would be close enough.
View attachment 651159 View attachment 651158
PS I wonder if this is a ghost thread...................................
Sometimes a generator will make power that is "too dirty" for some electronic devices ,
/ Generator question #25
I dont suppose there's an easy explanation between dirty electricity vs clean electricity. I know the difference between 114 volts and 120 volts...........
/ Generator question #26
"easy explanation between dirty electricity vs clean electricity"
Clean is less than around 5% THD (stands for Total Harmonic Distortion) - a fancy way of saying a more pure sine wave. Generally speaking, "normal" generators (non-inverter types) cost a few hundred$ more if they are "clean", but not always.
If you're shopping for a larger generator, any that ARE "clean" will almost always BRAG about it; phrases like "less than 5% THD", "clean power", "electronics safe", are the type of comments a seller will use. If they do NOT brag about it, that unit is almost guaranteed to NOT be "clean".
A lot of welders that have electronics are NOT waranteed if they were used with a "dirty" generator, the old buzz boxes could care less but won't run very hard unless the genny is LARGE.
Supposedly a few of the latest generation inverter welders are "tough enough" to not care about clean power, but most want less than 5% THD or warranty is void... Steve
/ Generator question #27
I've seen user guides for battery backups and UPS's state specifically that the warranties are void if connected to a 'motor driven generator' and they don't mention exceptions for 'inverter generators'.
/ Generator question #28
"they don't mention exceptions for 'inverter generators'."
There are at least two reasons that might be -
1 - The term "inverter" is generic - it only means that the device changes DC power to AC - I've seen some with a square wave output, others with a "trapezoidal" output (AKA "modified sine wave", a marketing term IMO)
2 - Warranty department is playing "CYA" and/or their "warranty" is in name only, til you try to collect... Steve
/ Generator question #29
One nice feature/problem with the smaller generators, is their size. It sure helps moving them around, but the more mass you can get moving, the more that helps on sudden loads...like when the water pump kicks in.
When I have my tractor hooked to my PTO generator, it has a lot of weight (mass) flying around, and so when the water pump kicks on, it has a lot of kinetic energy in motion. That gives the governor time to kick in, and you do not even hardly notice that it had a high load there for a second. But with portable generators, they really lug down, and you get a moment of brown-out. Speed of the engine dictates frequency, and so that lower amount of frequency (hertz) is hard on the pump and the generator.
It is not really "clean power" in definition, but it has a lot to do with better quality power.
/ Generator question #30
I had that same generator for 17 years. Easy starting and reliable. Late last year it fried some surge protectors in the house, and I found it was making 340v at the 220v plug and 170 on the 120 plugs.
I replaced the AVR without fixing the problem, and gave the generator to my electrician neighbor. In short order he found a bad connection on a wire coming from the AVR. It's back to purring like a kitten!
2019 GALYEAN...
KMC 3pt 20' Field Cultivator (A60462)
KMC 3pt 20' Field...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2017 Case CX145D (A60462)
2017 Case CX145D...
159120 (A60430)
159120 (A60430)
