Generator question
/ Generator question #1
John White
Gold Member
Newark, Oh
Bob Cat Ct335
I have two Harbor freight generators. I was checking the out put with a vom meter and here is what I found. On a house hold recpticle you have three plugs. One is ground, one is netural and one is 110-120.(hot) In checking both generators I find that one terminal is ground and 60 volt on each of the either two terminals or 120 when checked together. Some one said that these generators are designed to only run power tools, and will even damage some of them, if they have any diodes in them. And said never plug any thing electronic into them. I have two other older generators and you get a 120 volt reading when you connect between hot and netural or hot and ground. I am wondering if any one else has checked their China made generators. Maybe some one else more elightned can answer this question.
/ Generator question #2
I have a harbor freight , and it measures 120 volt at the outlets.
I've never heard of 60v at the outlet.
Plug a 60 wat bulb in it and see how it lights.
/ Generator question #3
I've never heard of that before.
I did have an odd issue with a small 3500 watt genny. it had a 220 outlet but it did not put out 2 even 110 volt circuits. so you could not feed a split phase panel. I found out the hard way by burning out a garage door opener control panel.
It was designed for 220 volt loads, but not two 110 volt loads.
When I checked the output, one hot leg would be 180 and the other would be 40. It would float around. 220 volts between the 2 hot legs, but varying between each hot and neutral.
I have never heard of my problem before or since.
JB
/ Generator question #5
What you have is called a floating neutral, which is standard on most newer gen sets. What problem is it causing you?
The problem that some people have with gensets damaging power tools useally stems from under sized gensets for their particullar needs. For example if your circular is slow at start up is bc the genset can't keep the voltage high enough which lets the current rise, which in turn creates too much heat and eventually burns out the motor winding in the saw. The same saw on a larger genset will work fine as the voltage will stay at rated levels and cause no problems.
Also the problem with the electronic having issues has more to do with un pure sine wave coming from the recitfier which is again letting the heat build up. Useally you get what you pay for.
Hope that helps.:confused2:
/ Generator question #7
Misinterpet question on previous post I think. Low voltage is because noload is sensed by governor/output with DVOM. Circuitry in plug config is diffrent from houshold as they are isolated from earth with rubber wheels/feet not ground rod or plumbing. With household hookup and ground rod is installed tang in recepticle is usually suggested popped.
Hope I did not make it worse for you.
Gary
/ Generator question #8
If my understanding is correct the Navy has used a similiar setup on there ships for years. The idea is that you won't get electrocuted as easily with 60v to ground verses 120v. I don't want to test the theory. If that's true then it was done on purpose because gensets find there way into unfriendly territory with wet ground etc.
/ Generator question #9
I have a 6500 peak / 5000 watt Coleman generator Floating Neutral generator.
yelbike is correct about the generator sizing
I am a licensed electrician and I took 1 year of generators as a college course
With John Whites OP I am confused with the supplied info
The generators might have some form of open circuit voltage regulation ??
I would you suggest you plug in your kitchen non electronic kettle filled with water and do a load test.
You can not hurt a resistance based kettle at 120 VAC 60 HZ.
Craig Clayton
/ Generator question #10
Gary either way your correct. Sort of...anyway. He has 120V from hot to neutral just not to ground so its not a sensing issue. You said it correctly when it comes to the bond terminal is not grounded in the receptacle. The reason for this is they are allowing for an external ground (ei..ground rod) for a permenent installation. If all your using the genset for is temporary and portable power you can ground the bonding terminal in the recepatacle or.........
If I've confused you (and myself :confused2:) forget every thing I said above and do this:
Make an adapter with an old extension cut the female end off. Now use a GFI receptacle put the black wire for the cord to the gold screw terminal on the receptacle, put the white wire on the receptacle' silver screw. Put the green wire on the green screw. Now add another wire for the ground terminal (green) to the neutral (white) terminal. This now becomes your "system ground."
Now when you plug your adapter, you will have ground fault protection and you'll overcurrent protection will come for the generators either fuse or breaker.
And the navy 60v is not about safety. You are probably thinking about the cathodic protection system which is another tread for another day after another beer.:drink:
Wow that was long now I need a beer:drink:.....and spell check!!:drool:
/ Generator question #11
Thanks yelbike,
I knew what I wanted to say but got tongue(mind) twisted in my desire to help. I am new to this stuff and want to help but not always comes out like I think. Maybe I should of had that beer first. Canadian Ale Of Course! Oldtime Cinci drinker.
Gary
/ Generator question #12
I finally decided to check the outlet voltage on my 20 year old 7000w Generac generator this past weekend while in middle of all day use. I knew it wasn't and never did put out 120v because it wouldn't run my microwave, toaster and coffee makers always took longer, I put the volt meter on outlet at the the generator and in house, the readings was 114-115 volts.
So I guess this summer it's time to update it to something that will put out 120 volts, on the assumption that they do make generators that does put out 120 volts, 119 probably would be close enough.
PS I wonder if this is a ghost thread...................................
/ Generator question #13
Probably nothing wrong with it. 20 years ago it may have still been 110v. In any even it should pump coffee to beat the band.
/ Generator question #14
115 is not abnormal. Typical range is 110-125VAC
Check your in house outlets while on utility power and see what you're getting.
/ Generator question #15
Speed up the engine a little, most will put out more voltage then...
SR
/ Generator question #17
I haven't checked my 8000 E model by Generac but it is powering this computer as I type this along with everything in the house except the stove and HVAC. Plenty of hot water also.
/ Generator question #19
I checked most of my house outlets and I get 119-120 volts but I forgot to check them 20 years ago. The generator seems like it's turning quite fast til the hot water heater kicks in but thats on a timer, it's on a governor so never touch the carb or battery, best starting motor I ever seen, it gets used 3-4 times a year, last weekend was the most it ran in two years. I only changed the oil 3-4 times since I owned it so no problem on durability.
I thought maybe there was adjustment on the generator side somewhere but probably a fixed setting and I dont where the HZ setting is on my multi meter. It wont run the micro but that's no big deal, I just like have my toast to keep up with my coffee, this summer I'll check for a up to date generator, 7-8000 running watts, preferably quiet running watts that puts out 119-120 volts, oh by the way I already crossed Honda off the list because I'm not in the $40.00/sock club.
/ Generator question #20
Hows it do on the toaster or microwave? Be interesting to see what the volts are.
I'd say the the com is right up there with running water as necessity items so thats good.......
2020 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 KENWORTH T680...
UNUSED FUTURE CW70-59" HYD COMPACTOR WHEEL (A65055)
UNUSED FUTURE...
2007 JOHN DEERE 450J LGP CRAWLER DOZER (A63276)
2007 JOHN DEERE...
2008 JCB TLT35D ROUGH TERRAIN TELESCOPIC FORKLIFT (A65053)
2008 JCB TLT35D...
UNUSED SDLANCH SDLC1220-12'X12' HIGH END CARPORT (A65055)
UNUSED SDLANCH...
2017 Ford Fusion Sedan (A64557)
2017 Ford Fusion...
