Branson steering cylinder leak
   / Branson steering cylinder leak #1
sidecarist
East TN on the mountain
Branson 4520R
Help.... I have a Branson 4520 with a steering cylinder that leaks from both ends. its a steady drip when its running.
The cylinder is captured between cast end caps that are bolted to the axle. When the steering wheel is turned the cylinder moves a small distance between the end caps, 1/16"-1/8" or so. I'm assuming that this small movement has worn the end cap seals.
I've never taken this type of cylinder apart before. I'm guessing that it is just O-Ring sealed. Does anyone have a service manual that shows the cylinder construction and seals?
Any help/guidance will be appreciated.
   / Branson steering cylinder leak #2
I see this is an old thread. Did you ever get an answer? I'm dealing with this issue right now.
No answer from here... I ultimately found out that it was a known problem from Branson. They will replace the cylinder with an updated design that has a tie rod bolt holding the end caps in place. I waited too long and they wouldn't cover it under warranty... I don't recall the cost but it wasn't too bad. replacing the cylinder wasn't hard at all just be careful to not break the tie rod ends. Tie rod end pullers are available for rent at many auto parts stores. I also measured the overall length of each end so I could put them back in the same place to maintain alignment.
Hope this helps...
   / Branson steering cylinder leak #4
how did you get the cylinder off the tractor? I can not access the two top bolts or I am not trying hard enough. IT feels like I am trying tho.
LOT LOCATIONS (A54313)
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
2018 Dodge Grand Caravan SXT Van (A53424)
2018 Dodge Grand...
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
2017 Nissan Frontier Ext. Cab Pickup Truck (A55852)
2017 Nissan...
66'' root grapple (A53421)
66'' root grapple...
