Trailer customization suggestions
/ Trailer customization suggestions #61
:mur: Your a very difficult person your wife must be an angel to put up with you...............:D
/ Trailer customization suggestions #63
Owner says theyre welded in place. They dont slide??? Makes no sense, but thats what he says.
I'M all done with this thread...........:laughing:
I wish it had ramps like the ones on my Big Tex.
/ Trailer customization suggestions #65
From the worn paint, it sure looks like they used to slide:
Sure would be nice if they did, but they still don’t slide close enough together for my liking for my zero turn.
On edit: owner just verified ramps DO slide, but only about 10” inward. The most narrow setting is 80”. My zero turn is 58”.
/ Trailer customization suggestions #67
The most narrow set is 80" outside edge to outside edge of the outer ramps. That's 6'8".
What's the inside edge to inside edge of the outer ramps?
Your zero turn is 58" outside edge to outside edge of your tires. That's 4'10".
How wide are your tires spaced apart inside edge to inside edge?
If your inside tire-tire measurement is = or > than the inside edge to inside edge of those ramps at their narrowest setting (and I'd guess they are just by looking at it), you're good to go.
/ Trailer customization suggestions #68
If this area is less than the width of the inside of your zero turn tires you're good to go...
Inside edge to inside edge on outer ramps slid all the way in is about 45” inches. So if my zero turn tires are 58” outside to outside and 32” inside to inside, I’m only getting about 7” of tire on each ramp. It would work, but I’m not real comfortable with that.
/ Trailer customization suggestions #70
What about this width for your zero turn?
Yep! I already mentioned that in a previous post.
It would work perfectly width-wise. I should easily be able to straighten up once on the deck.
I was thinking of overlaying mesh on those 2 ramps and leaving the right (3rd) ramp alone for bigger stuff
/ Trailer customization suggestions #72
Buy it! :D
LOAD OUT AND SHIPPING (A65579)
LOAD OUT AND...
10' Rotary Hoe (A64126)
10' Rotary Hoe...
2005 American Iron Horse Legend Motorcycle (A64127)
2005 American Iron...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
Frontier Forks (A64127)
Frontier Forks...
Kubota M125X (A60462)
