Trailer customization suggestions
/ Trailer customization suggestions #21
Tilt deck
/ Trailer customization suggestions #22
If you're going to go buy it, put your zero turn on your existing small trailer and tow it there to see if it works. If it does, tow the big trailer back with a small trailer and ZTR on top.
Aaron Z
”tilt deck”
$7000
I mentioned in a previous post I would rather do a tilt deck, but they’re like $7000 new and they are usually a minimum of 16 feet long.
Aaron Z
Yeaahhhh, I don’t see that happening :laughing:
/ Trailer customization suggestions #25
Way better for loading skid steer, mini excavator , No ramps to deal with, Better resale value , I love my tilt deck...
You also love spending other people’s money :laughing:
If I could find a short used tilt deck over yeah maybe, but Can’t find one. I have looked for a long time.
I can get this trailer for $1500
/ Trailer customization suggestions #28
You have enough clearance underneath, for a lift assist spring, I would look at the spring style that uses a trailer spring mounted underneath the trailer and sticks out the back a little bit to provide spring lift assist for the ramps.
Some pictures of someone's version of this, source: How to build a Self Lifting Trailer Tailgate – DIY METAL FABRICATION .com
Aaron Z
What I would like the most is a full width screen ramp with reinforcement for a heavy piece of equipment and a spring assist to lift it up.
Or a tilt trailer :laughing:
/ Trailer customization suggestions #30
All you need is a bunch of pieces of 2x2 (or so) angle, some flat strapping and expanded metal and you can convert your existing gate to a spring assisted screen ramp :D
Aaron Z
/ Trailer customization suggestions #31
Looks like it may have leaf springs, but not much clearance:
It has more clearance than my dual tandem gooseneck.
/ Trailer customization suggestions #34
If it works for your needs other than the ramps, I’d buy it, then remove the lights and ramps. Build two wide ramps add spring assists and led tail lights along the lower edge of the trailer. Something like these mounted length wise.
Attention Required! | Cloudflare
/ Trailer customization suggestions #35
/ Trailer customization suggestions #36
�ilt deck
$7000
I mentioned in a previous post I would rather do a tilt deck, but theyæ±*e like $7000 new and they are usually a minimum of 16 feet long.
For only $1,500 (no tax) it probably does make good sense to buy it and try adapting to your needs.
I could get by with center ramp removed and two outer ramps set up for variable spacing. Adding a full mesh overlay ramp on the two ramps and a spring assist would make it great. I dont think those little Buyers brand spring cable assists would be enough and if they'd work???? Doesnt look like it.
Even if my final cost is $2500-$3,000, I think I'm still in pretty good shape for a 12k deck over.
Ill be darned if I can find a used 10-12K deck over with a full width reinforced ramp.
/ Trailer customization suggestions #38
Make the center and left ramp one, Then the right extent it and on the side put angle iron so it sits on the side of the center ramp....
/ Trailer customization suggestions #39
looks kinda tiny for a skid steer, my trailer is 14' and its the smallest I would go. The angle looks too steep to go up forwards without tipping, the ramps need to have some structure underneath or they will collapse. and if use it for skid steer there will be too much tongue weight
Hmmm.
You mean make a wide ramp of the left and center ramp? I get that (and I like it for the zero turn-lighter in weight, easier to handle), but I don’t get what you’re saying about the right side ramp..... :confused:I think you’re saying leave it alone? A little unorthodox, but not a bad idea. Not sure if a skid steer with make it up that configuration, though.:confused3:
2016 FORD EXPEDITION SUV (A59912)
2016 FORD...
2022 BOBCAT T870 SKID STEER (A64279)
2022 BOBCAT T870...
RoGator RG1100C (A63688)
RoGator RG1100C...
2017 Case CX145D (A60462)
2017 Case CX145D...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
CAT CB34 (A60462)
CAT CB34 (A60462)
