Battery disconnect switch
/ Battery disconnect switch #1
JAMES NICHOLSON
lisbon.ohio
cub super lt1550,ford lgt 100,simplicity,wheel horse, murry
63425_I.jpg For what it's worth. Just a mention of what I consider to be a very important add on for lawn and Garden tractors. Adding a disconnect switch between the ground cable on the battery and the frame ground post. I have several lawn and garden tractors and have installed one on each one. It lessens the chance of a fire due to rodents chewing on the wires and also battery drain do to an unknown parisitic draw. The Harbour Freight ones are perfect for small equipment but I dont know if they will handle a high current draw from a large piece of equipment. It sure gives me piece of mind knowing the electrical system is dead.
/ Battery disconnect switch #2
I put Blue Sea switches on all my RV's. I also put one on my sawmill. There out in the weather 24/7 and never had one fail.
Great idea !
/ Battery disconnect switch #4
Have one, but don't think it would handle the explorer that goes dead after 4 days. --- Looks like small equipment use only but still a good idea.
/ Battery disconnect switch #6
Any thing better than nothing.
/ Battery disconnect switch #7
View attachment 650589 For what it's worth. Just a mention of what I consider to be a very important add on for lawn and Garden tractors. Adding a disconnect switch between the ground cable on the battery and the frame ground post. I have several lawn and garden tractors and have installed one on each one. It lessens the chance of a fire due to rodents chewing on the wires and also battery drain do to an unknown parisitic draw. The Harbour Freight ones are perfect for small equipment but I dont know if they will handle a high current draw from a large piece of equipment. It sure gives me piece of mind knowing the electrical system is dead.
Does the key stay in the switch? Good idea though.
Yes the key is removable. I install the switch somewhere under the hood or seat close to the battery and the cap covers the opening when the key is out.
/ Battery disconnect switch #10
I have one on my Yanmar that I use for mowing. Its nice knowing a thief will have to figure it out first.
/ Battery disconnect switch #11
I have a couple of those on small equipment... they work....
We use these for vehicles... & they work great...
NAPA Battery Disconnect Switch
/ Battery disconnect switch #12
I have a couple on stuff that I don't use very often. But they are a screw type that mounts directly to the battery terminal. You can get them cheap off of ebay. I found that they come in two styles, cheap Chinese and US made. Get the US made ones.
/ Battery disconnect switch #13
alternatively an Anderson connector is a good way of isolating, they are also a good design as they wipe on disconnect/reconnect which keeps the contact relatively clean.
3142 (A63117)
3142 (A63117)
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
Doo Little XTM-8418 Trailer (A66285)
Doo Little...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2014 Chevrolet Traverse (A62613)
2014 Chevrolet...
