Howse cutter issue
/ Howse cutter issue #1
okiecraig
Creek County, OKlahoma
1972 MF 135 diesel, Kubota L3940
Have a light weight 5 ft Howse cutter that bangs loudly every time I engage PTO. Everything lubed, greased and oiled but this banging business cant be good for my PTO on Kubota L3940.
Any thoughts? IS iT just junk? Has done this since I got it.
Thanks
/ Howse cutter issue #2
Thanks
Can you post a video or sound clip of this?
/ Howse cutter issue #3
Likely the noise is the blades swinging and impacting each other or the blade holder at start up. Try engaging the PTO more slowly.
/ Howse cutter issue #4
Many independent PTO's turn on pretty hard (on/off switch).
Causes the swinging blades to impact on startup.
My tractor/brush mower does the same thing.
/ Howse cutter issue #5
Yep. I had a John Deere 850 that did the same thing. It was difficult to feather the PTO clutch. I would idle the tractor down, and then partially engage it, and then engage it fully. That did the trick.
It wasn't the mower, it was the abrupt PTO clutch.
/ Howse cutter issue #6
I think it's pretty common when the PTO is engaged quickly. Hopefully that's all it is.
Thanks
Think you guys have nailed it! I can't feather the PTO swtich like I can my MF 135; the Kubota is abrupt on and off and the clutch does not seem to interact with PTO. Maybe if I always reach under and spin the bowl a few times before I start cutting for the day.... or maybe need a better cutter. :)
Thanks much.
/ Howse cutter issue #8
Or maybe a tractor with a better designed PTO? Sadly, they seem to few and far between now days.
I'm glad I still have my 20-year old JD 870 which has an actual clutch on the PTO that one can feather in easily for heavy loads.
/ Howse cutter issue #9
Idle down as low as you can when you engage the PTO switch. Maybe flick it on momentarily, then full on.
/ Howse cutter issue #10
I seriously doubt a different cutter would make a difference.
Its the abrupt startup of the PTO causing the blades to bang.
Just turn the PTO on at idle and you will be fine.
2007 Freightliner Columbia 120 S/A Day Cab Truck Tractor (A61568)
2007 Freightliner...
UNUSED IRGC40 HIGH-END ELECTRIC MINI GOLF CART (A62131)
UNUSED IRGC40...
2017 Ford Fusion Hybrid Sedan (A61569)
2017 Ford Fusion...
New/Unused Landhonor Electric Hoist (A61166)
New/Unused...
2011 Ram 1500 Pickup Truck (A61568)
2011 Ram 1500...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
