1980s International 254 Resurrection
/ 1980s International 254 Resurrection #1
RossCountyRam
Ross County, Ohio
International 254
My wife's sister acquired an International 254 with her home purchase 5 years ago. It has sat in the barn since then, untouched. Wishful thinking was that it would fire right up. No luck. And with no light or power down there, getting it running in place was not going to happen, especially with my limited skill set. So I wiggled it out of the barn (thank goodness for it being gravel floor), dragged it up the hill with my truck, and loaded it up for the 140 mile trek home.
IMG_0539.jpgView attachment 648075
After I got it home, I tested both the battery and starter. Each came out looking good. But there is still an electrical problem as I can't get any power to the key. Cannot seem to track it down.
At this point I am doing no good, so I took the tractor to an ol timer down the road. His business is tractors, and he has been in it for 50 years. I told him I had the starter out and it's good, along with the battery, and all I needed was power to the key to see if it fires up. Didn't take him long to figure out the electrical problem, but the engine won't turnover. I heard the dreaded words, "engine is seized up." Dam, what luck.
So, all I can do is explore the options. I know there is a complete K3F engine down south I could have shipped north for a pretty penny. Or I could always part it out, the loader may bring what I have in the tractor at this point.
But I really don't have the covered space for a non-running tractor laying around in pieces. After a night of thinking about it, I decided that it made the most financial sense to swap in a running engine, even with the high cost of a replacement. BUT, I better make sure it is the engine that is seized....
I felt somewhat confident that I can tackle a lightweight teardown of the engine because of available resources such as YouTube, this site, and all the paperwork the previous owner kept in good order, so I was going to find out what exactly is seized. Hopefully the culprit is on the top end.
The first thing I did was put a wrench on the crankshaft bolt and sure enough, it doesn't budge a mm. Bummer, but I figured that would happen. Next, I drained the coolant. Then I removed the valve cover. This engine is the Mitsubishi 3 cyl diesel K3E.
From what I've read, they are good little engines that run and run. It makes no sense this one is locked up given it supposedly ran when parked and it has been out of the weather....
Now the valvetrain needed to come out to get to the head bolts.
There are 11 headbolts, and once out, I am looking at this:
Piston 3 (?) looks deceiving. That is nearest exhaust so a bit more carbon built up and I had rubbed my finger around the edges so that explains the marks. It is also close to TDC so it presents itself in a different light. In person, I see no reason any of these pistons are stuck. Everything looks good to my untrained eye. The underside of the head looks good too- gasket in good shape, carbon is pretty evenly distributed, I see no gouges, cracks, burnt looking spots...
So now my thought moves to the crankshaft and underbelly of this beast. But first let me soak the pistons in a little bit of penetrating oil and some 30W overnight. The next morning, I try and rock the crankshaft one more time and nothing happens. I figure might as well remove the starter and put a pry bar on the flywheel to double check. Low and behold, the flywheel moves easily. What the crap?!?!?!
Unbeknownst to me, the two bolts that hold the starter in place are different lengths. The bottom bolt is supposed to be the shorter one as the longer one will bottom out, ON THE FLYWHEEL. This picture shows the correct bolt in place but if you look at the flywheel, you'll see the mark the longer bolt made. This has to be the reason the engine did not turnover.
I take full responsibility for this as I am the one that removed the starter early in the game. Only thing I can do now is accept my blunder and put things back together. If I ever come across a 'seized' engine again, you can be sure I check the crankshaft AND flywheel.
As of this morning the head is cleaned up a bit, oil is drained and new filter awaits installation, and old diesel is drained. Now just waiting on gaskets and I can get this thing up and running hopefully.
Here's a picture of the fuel cap I think is interesting and also the 2 newest additions to our herd have found a spot to relax under the bucket...
Thanks for reading about my unnecessary adventure and boneheaded mistake. Stay tuned for a quick video of it running next week.
/ 1980s International 254 Resurrection #2
Wow live and learn... My buddy changed his water pump on a Mack and left a screwdriver on the engine when he started it fell into the fan and shot into the radiator so a thousand dollar mistake.. At least you got it running ,Have fun and nice baby goats they're cute.....
No such luck.
It doesn’t want to start. I think it is a fuel issue. I followed the book on bleeding the air but may need to do it again.
/ 1980s International 254 Resurrection #4
Wow. I'd been flipping out if that happened to me. Good job on figuring it out!
Sharp little tractor!
/ 1980s International 254 Resurrection #5
Excellent thread. Keep us posted please. Cute kids too!
Checked my fuel system and it is all good. No more air. Fuel cutoff solenoid is good too. I can hear and feel it working. With the battery being helped, engine turns over good and fast, sucking air and benching a lil black smoke. Also put the voltmeter to the glow plugs and they are fine.
For now, I’m stumped and tired of messing with it. Need it to just fire up and run.
Well I am down to #3 valve not delivering from the fuel pump. I took the insides out and made sure they look good, clean, and then put it back together. I have the part diagram to reference. Couldn't the engine start with two cylinders getting fuel? Any advice to go from here?
Got it to run, and run it did. Dam near away! Ignition switch wouldn’t shut it down so I had to cut off fuel supply. The fuel cutoff solenoid clicks on quickly with key and is delayed when cutting power, maybe 5 seconds. I wonder if that is an issue?
I think it was running on 2cyl because when I checked #3 fuel line at the injector I get nothing. Is there anything else I can do besides go after a used pump? Financially speaking it would be similar cost as trying to find someone to rebuilt mine?
/ 1980s International 254 Resurrection #11
I wish I had your answer but all I have is my advise and my experience on "used" parts like this hasn't been good. I would stop at a reputable diesel pump shop with pictures and as much info on the pump as possible and talk to them. I don't understand why more diesel guys on here aren't chiming in to help! I wish you luck and please keep is posted.
I would also ask the shop if there are any tricks to pull the pump as to make the installation easy for the timing and such. Good luck.
/ 1980s International 254 Resurrection #12
I went back and looked at the 1st post by the OP. There is a picture of an I&T manual there. Therefore I'm assuming that he has one. All the information he needs to remove the injection pump will be in there.
Removal and installation shouldn't be an issue, like you said because of the manual. It just drops down into the block. I will post a pic or two when I remove it.
This afternoon I will ship it to TN and have him rebuild it rather than sourcing a used one. Like my uncle said, I already have a used pump...
As far as the engine running away, is it possible it did that on 2 cylinders? I've learned out of adjustment valves or a bad injection pump can cause that condition, but haven't grasped what a non fueled cylinder would mean to the situation. Thanks for your time.
/ 1980s International 254 Resurrection #14
I listened to your video and to me it didn't sound that bad. Things always sound worse when you are right there. The person rebuilding your pump should be able to confirm if the governor mechanism is still functioning as it should.
/ 1980s International 254 Resurrection #15
hopefully the pump will fix it. some odd things going on to me, and the pump is really the most complicated thing in the whole engine. My AC just has a lever to pull for fuel or no fuel. the key just just turns over the starter and puts power to the gauges. it will run / work with the key in any position after its running. only way to shut it off is to pull the fuel lever. correct operation according to the instructions on the dash.
I have an operators manual on the way to shed some light on controlling this tractor.
Pump is back in. The K3E runs and sounds great.
She fired up. - YouTube
But wait, what the crap is that?
International Cappuccino 254 - YouTube
Hydraulic cappuccino? For the record, the fill cap was on cockeyed so maybe air into the system? The rear hitch raised and lowered barely, front loader did not budge. Thoughts?
The tinkering continues. What a headache haha.
/ 1980s International 254 Resurrection #19
That hydraulic fluid looks pretty white. That means it has water in it. You'll probably need to flush the whole system several times to get all the contamination out. I would guess that the bubbling out through the fill tube is air. Generally look for leak on the suction side.
Well I got it wired up, and put back together. She runs. FEL works as should. Just need to top off hydraulic fluid, flush out radiator and a couple other small things but it痴 working.
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
832620 (A61166)
832620 (A61166)
Deere 310SK (A57148)
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
2014 Chevrolet Silverado 3500 Crew Cab Utility Flatbed Truck (A60352)
2014 Chevrolet...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
