Mahindra 2638
/ Mahindra 2638 #1
bluetecnc
Soon to be Mahindra 2638
I am considering purchase of the 2638. I have several questions about this model. The 2638 is an HST but only has brake pedals, forward/reverse pedals, a lever to disengage the PTO, and not a "clutch pedal" like the 1600 and MAX series. The specs states it has a "damper clutch". What is a damper clutch? I have read that some consider the 3-point hitch has a design flaw. What is the flaw? How can I tell from the ID plate whether the tractor is a 2019 or 2020 model?
will appreciate any input!
/ Mahindra 2638 #2
I have a 2538 (predecessor to 2638 and same frame, chassis, power train). Had mine for almost 3 years now. 1150 hours, and no trouble other than one hydraulic cylinder seal that had to be replaced. The HST is a useful tranny IMO, because of it's flexibility.
Not sure what could possibly be a 3 pt hitch design flaw. I use mine all the time with multiple implements and have had no problems.
You'll love the PTO lever to disengage when hooking up large PTO implements, like bush hog, mower, etc. Makes it a breeze to line up PTO drive shaft.
Dealer should be able to prove the year of manufacturer and show you on the ID plate, which you can confirm easily.
If you buy it, I have a couple of suggestions:
* Have dealer fill tires as part of the deal
* If you have large areas to grade or mow, consider getting cruise control. Should only be $200 or less. I got the kit and did it myself in 15 minutes.
* if you will store the tractor outside, have dealer install a hidden kill switch to deter theft.
* Have dealer do latest computer update before delivery.
Good luck with your decision. I think you'll love the tractor. It's a real work horse.
/ Mahindra 2638 #3
The 3pt hitch flaw that I have seen is that the top link can not be used in all the pin locations and get the full amount of hitch travel without the top link binding on the PTO shield. So you may be in trouble with the top link in a lower pin location on the tractor. :confused3:
/ Mahindra 2638 #4
Elaborate on this comment please. i myself am not exactly sure what you are speaking of. I have a new to me 2638 so i may simply just no be aware.
Thanks
/ Mahindra 2638 #5
To the left of the seat, there is a lever. It is the 3rd safety mechanism to engage/disengage the PTO shaft. (2 on the dash).
By moving this lever forward, you disengage the PTO shaft, and essentially put it in "Neutral". You can then spin the PTO shaft with your hand to line up the splines on the shaft and the implement female fitting. Makes hooking up different PTO implements a breeze. No busting knuckles to turn your implement drive shaft to line up with the tractor spline.
Hope this helps.
/ Mahindra 2638 #6
Hope this helps.
Ok! that makes much more since. Yes that lever is nice. I read the comment that there was this magical lever that would disconnect the pto shaft for you with out have to get off the machine. i was almost upset for a second there that i didn't have this magical lever!
/ Mahindra 2638 #7
I'll have to re label my Mechanical PTO Lever to "Magical PTO Disconnect"...:laughing:
/ Mahindra 2638 #8
Duffer, did you have issues with your cruise control (magnet) not holding the pedal? Mine doesn’t hold very well.
/ Mahindra 2638 #9
Haven't had a spec of trouble. And I use it ALL the time. Check your elec connection, and also see if you're using the correct hole to mount the magnet.
/ Mahindra 2638 #10
I've had a 2638 for a year and put about 220 hours on it. I grew up on tractors with gears and a clutch, spent some time on shuttle shift and power shift machines but most of it was good old geared tractors.
The HST is nice, if you've got a bigger field to mow get the cruise control kit. I've got mine on order because while I don't have big fields to mow I have enough of it that my right knee gets tired of pushing on a pedal constantly.
I added hydraulic remotes to mine because I need them for a few implements, they do their job but have no detent to "lock them" to constant flow. I made a latch to hold it that took my about an hour to figure, fab, paint and install. The paint drying took the longest.
The three point: It works the way it should, I've not noticed what someone else mentioned about the top link not jiving right in all of the pin holes, my toplink has been in the top hole for about a year and I don't think I've moved it. I installed Pat's quick hitch links, makes life SO MUCH easier. It seems to me the swing geometry of the three point links just doesn't seem right to hook up to some things easily. It always worked perfect on captured pin equipment but not so much for me with equipment that has pins that stick out and the balls have to swing onto them. Installing the Pats hitch fixed it, equipment hookup is no longer a painstaking task..... remember I'm only 40 and I've been doing this since I was 10 so its not my first tractor or equipment to hookup... overall I'd give the 3 pt hookup process a C- on this tractor, with the Pats it is every bit an A+ game.
The one flaw I will give this tractor, and I read about it and wondered how, is that the three point lift arms will bend easily if you are pushing something backwards. In my case I had my 7' boxblade on it, pushing some sticks and brush (nothing heavy and not moving fast) and the edge caught a stump and bent a lift arm. In 30+ years on doing stuff with a tractor I'd never bent a lift arm, my dad and uncle easily have double the time of me and they never have. They bend easily, watch out, they're about $350 to replace. (Now of course I took mine, heated it up, slowly bent it back into shape with some wood blocks and pallet forks on my loader, it took about two hours of heating/pressing/heating/pressing to get it straightened out. It hasn't bent again yet). Amongst my farm friends I don't know anyone who has bent a lift arm and I've been accused already of being rough on this tractor. Its nothing I haven't done with tractors in the last 30 years and in fact it was less work to bend this than the same work I've done in the past and lost traction with tractors having 10-20 more hp and 2-3000 lbs more weight. Frankly the lift arms are not designed to push like that and can bend easily.
The three point lift lever next to your seat needs a depth stop. Meaning when you lift your bushhog to make a turn and drop it the lever should end on a stop so the mower is the same height. Mahindra does not make one, my dealer looked at my old tractor that I traded in and said 'yeah that would be handy," I later made one.
The toolbox location and size is poorly placed and grossly undersized. I mounted a new one above the loader couplers to the right of the hydro pedals, hangs off of the foot platform just enough to not be sticking past the tractor. It works well. The factory toolbox I placed on top of the left rear fender as a place to put extra lynch pins and the washers for my Pats hookup.
I installed a canopy on the ROPS, I also put lights on the front corners of the canopy that help illuminate the immediate right and left where the forward lighting does not, lights up the loader at night, its far enough forward to not collect bugs in your face at night. I also placed a rear light on the canopy and one on top of the fuel tank cover that keep the rear lit up nice in the dark. I also placed flashing lights on the rear of the canopy that are wired into the flashing light system and turn signals of the tractor. Makes it easier to be seen on the road at night if you have an implement behind you.
Overall I like the tractor, the 55 hp Ford utility tractor I owned the previous 15 years, it was 2wd with a loader. Overall it was a good tractor and I did alot of work with it. This new one is 2500 lbs lighter and 15 less horsepower, I find it does most all of the same work. Loaderwise my last one would pick up a house and if I had enough weight on the back I had traction to move it, if it wasn't muddy and the front end didn't sink or break. This new tractor will not pick up as much but the traction issues aren't there, the hydro lets you modulate your speed as you need, gets the job done faster just less per lift (of whatever you are moving en masse). I run a 6' bushhog on the last tractor and this tractor, my last tractor rarely ever acted like it had a load with that mower, you could move across a field as fast as you could sit in the seat or that the mower could suck in and spit out. Not so much with my 2638 BUT the 6' mower isn't too much for it and it is easy to regulate your speed in the thick stuff. It doesn't ride near as nice as heavier and longer utility tractors that I am use to but it has a good seat.
I use my tractor with a finish mower on my yard so I have hesitated to load the rear tires, I might do this eventually but I have found the R4 tires don't cut or create ruts but they do create compaction. Over the winter feeding horses in the wet I found it just didn't sink on the surface wetness and create ruts like my last tractor did. That being said I'm not impressed with the R4 traction, they float well though which is more of what I need now.
In the end I am pleased with it and to do it all over I'd buy it again and do it all the same way so far.
/ Mahindra 2638 #11
I know my dealer had some issues with the cruise control magnet not holding. they had to put in a shim on the mounting bracket to get it to sit perfectly parallel with the HST Forward pedal arm.
one issue i had when i first brought it home was the nut that holds the magnet in the cup came loose from vibration and the forward pedal got hung up on the magnet essentially holding it in reverse! scared me as i was so used to my 3016 shuttle shift. i fixed it with a NYLOCK nut! been flawless ever since. FYI i did inform my dealer of that issue. told them to throw out the reg nut that comes with those kits and use nylocks!
/ Mahindra 2638 #12
Finally took a look and that was exactly my issue too. Realigned with piece of wood and hammer on that bracket. One whack,real easy. Thanks
/ Mahindra 2638 #13
I also have the 2538 ,And except for getting bad fuel last weekend and having to drain everything and get new fuel , I have not had any issues . I work it very hard every weekend,
/ Mahindra 2638 #14
Based on the number of posts for other Mahindra models, I think the 2538/2638 is one of Mahindra's best models as far a trouble free operation (with proper maintenance of course). I've had mine for 4 years, and have almost 1500 hours on it, and other than having the ECU updated, no problems of than a cylinder seal needing replaced.
There are very few real problem posts on this board for the 2538/2638. I haven't seen any PTO's not working, or major hydraulic problems. Or other power train major issues. There are only about 5% or less of us with cruise control and if that is the only real problem that surfaces....we're in good shape.
/ Mahindra 2638 #15
Mine is 3 yrs old with just under 500 hrs. I have had no 3 pt top link problems, After i installed a pats Qh Which i love , I did have to get a longer top link only for my old yanmar tiller that someone butchered up . tractor is a work horse for sure.
/ Mahindra 2638 #16
So you guys that say you have had no top link issues, is that with the top link in the lowest pin location on the tractor? You will not have issues in the upper pin locations, but if you want to use the lower pin location, I believe that there clearance issues.
Of maybe not, it sure looked like it to me though. :unsure:
/ Mahindra 2638 #17
Can only speak for me, but I've never moved the top link location in 4 years. With the adjustable top link arm it's easier to adjust the arm than move it, IMO. I used a PTO post hole auger a couple of times, and the pin went in the lowest setting, but no issues there at all.
I also have a Pat's Quick Hitch. Love it.
/ Mahindra 2638 #18
I've never used the lower top link hole and never found a reason to. I think mine is in the top hole and I have extra pins in the other two holes.
On my last tractor there were two holes for the top link and in the 15 years I owned it I never used anything other than the top one, I think I only had the top link removed from the tractor twice.
/ Mahindra 2638 #19
/ Mahindra 2638 #20
Great post! Can you tell me how you fixed the depth stop.... a picture or how you remedied the problem. Thanks so much.
2016 FORD F-550XL SUPER DUTY SERVICE TRUCK (A64280)
2016 FORD F-550XL...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
Towmotor/Lull/JLG/Barber-Greene Manuals (A63117)
Towmotor/Lull/JLG/B...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
UNUSED LANDHONOR RIGGING/BINDING CHAIN SUSPENSION (A64281)
UNUSED LANDHONOR...
2004 Isuzu NPR 14ft. Box Truck (A61573)
2004 Isuzu NPR...
