Dirt Moving Cutting a ditch
/ Cutting a ditch #1
Rutman
Bostic, NC
Yanmar sa424
I have some sloping land I want to cut ditches across to help with water runoff.
All I have to use is a box scrape.
Assume I’m driving left to right.
My question is should I drive on the high side and tilt it to the right or drive on low side and tilt the left side?
/ Cutting a ditch #2
Regardless of travel direction,low end (digging corner) of blade should be up-hill. Reason being that front of tractor will be pulled in same direction as resistance created by blade.
/ Cutting a ditch #3
That will depend on the profile you wish for your ditch, especially using a box blade;
with the cutting corner on the uphill side you will have a flat ditch,
with the cutting corner on the lower side more of a sharp containing ditch.
/ Cutting a ditch #4
May need to be on downhill side to remove dirt easier at first. Then uphill side to get the ditch bottoms grade the way you want it.
/ Cutting a ditch
Thanks.
Just what I needed.
/ Cutting a ditch #6
If the ground is quite sodded up, you might consider getting a roll over plow to help bust the sod up first so your box blade will cut a little better. But I am not sure how much you are ditching/putting in swales either.
KMC 14' FIELD CULTIVATOR (A64278)
KMC 14' FIELD...
2022 JOHN DEERE 17G EXCAVATOR (A63276)
2022 JOHN DEERE...
2021 TORO MRTX2500 68138HD STAND ON CONCRETE BUGGY (A63276)
2021 TORO MRTX2500...
UNUSED FUTURE HYD AUGER SET (A65055)
UNUSED FUTURE HYD...
LOT OF GRAIN BIN LADDERS (A64278)
LOT OF GRAIN BIN...
(2) CHROME STEP BARS (A64276)
(2) CHROME STEP...
