Grapple Precision Mfg Mini322DBL Grapple Review
/ Precision Mfg Mini322DBL Grapple Review #1
snabity
Elkhorn, NE
2020 JD 3039R, 1955 Ford 640
I live on about 4 acres of wooded property with approximately 20 acres of common area with horse trails, trees, and open grass. I finally decided to buy a 50 - 60" width rake grapple for my JD 3039R. My goal was to find a double grapple that would handle uneven loads and not be so heavy to limit lifting capacity.
When I started researching grapples, I went to the standard grapple companies, EA, Titan, Frontier, etc. I found their grapples to be very heavy with a single grapple for the width I wanted. I then saw an episode of Tractor Time with Tim, with Tim using a dual rake grapple with railroad ties on a JD 2038R. It looked promising.
I reached out to Tim at TTWT, and he sent me to Precision Mfg. I talked to Bill Reed, President of Precision, and he answered my questions. He told me the grapple I was interested in weighed only 261 lbs and made with AR400 steel. Even with this information, I was still skeptical of the weight, capabilities, and I didn't know much about Precision. I went back to the competitor's websites to compare again and started to waver on whether to get the heavy grapple and settle for one long grapple arm or stick to my specs. I decided to go with my original specs and ordered the Precision Mini 322DBL Rake Grapple with a double grapple that is 57" wide.
I had it shipped to my local JD dealer to install. The install was easy, and the JD dealer commented, "how light the grapple was", "impressed with the quality," and "it operates smoothly."
Now, time for the test. It performed better than I expected! I was like a little kid with a new toy. I didn't realize how many of the loads I picked up were uneven. The dual grapple functionality kept the unbalanced loads tight without falling out. I can't imagine doing work with a single grapple unless everything is uniform. The other benefit of the lighter Mini 322, I was able to pick up heavier loads at a time. Also, the grapple connected effortlessly on the JD tractor, making bucket changes a snap.
So, what are the negatives?
Precision grapples are not the most inexpensive grapples on the market retailing for $2495. They are priced similarly to other light-weight grapples that have only one hydraulic grapple arm. Also, I know it's minor, but I wished I could get the grapple in JD green. I saved $200 by using the TTWT discount code on Agfolks.com.
Overall, if you're looking for a light-weight, well built, dual rake grapple, the Precision Mfg. Mini322DBLSS double grapple is worth the look.
/ Precision Mfg Mini322DBL Grapple Review #2
:welcome: to TractorByNet! Pictures please.
Folks, photos of Precision Mfg Mini322DBL Grapple on JD 3039R
/ Precision Mfg Mini322DBL Grapple Review #4
Looks like a well made grapple. Keep us updated as you use it. Enjoy!
/ Precision Mfg Mini322DBL Grapple Review #5
I'm in the market myself for a root rake style grapple. My use would be as a bull dozer, plowing up saplings in dense clay with occasional 6" diameter rocks. I would also be carrying logs to cut for firewood, but that can be cut to reduce weight & make more trips. My tractor weight is close to yours.
Question: is your grapple robust enough for bull dozer tasks? Or in my case, should strength should trump weight characteristics?
/ Precision Mfg Mini322DBL Grapple Review #6
From your profile: you have a 1955 Ford 8N?
I have always believed that 1952 was the last year of the 8N.
/ Precision Mfg Mini322DBL Grapple Review #7
You should lprobably look at the EA grapples.
They look VERY tough....but they are spendy!
Yep, your right. Thanks for the info. I confirmed with my maintenance mgr. It's a 1955 640 tractor, not 8N. Learned something new.
/ Precision Mfg Mini322DBL Grapple Review #9
Congratulations! Like I said in the videos, I love the double clamp!
Tim
/ Precision Mfg Mini322DBL Grapple Review #10
I've seen Tim use the heck out of that grapple! Pretty impressive.
Just curious what the shipping cost was for it. That's one nice thing about EA - they build the shipping cost into the price of the grapple so you know up front what it's going to be.
My freight charges were $100. I like EA too, but they don't have a lightweight dual cylinder grapple in the 55" width category.
/ Precision Mfg Mini322DBL Grapple Review #12
Grapple "hunting" is a mind dizzying undertaking. I looked, asked, evaluated for two years. Finally - dealer installed WR Long third function and Land Pride SGC 1560 - rock & root grapple. 820# of AR400 steel. It still leaves me with 3000# lifting capacity. View attachment 650455
/ Precision Mfg Mini322DBL Grapple Review #13
My opinion is the black color looks way better than a green grapple would on your tractor. All green, is just way too much green. I like the black look on the Kubota's also.
/ Precision Mfg Mini322DBL Grapple Review #14
Shipping cost estimate should NEVER be a problem.
All grapple sellers will quote a shipping price for their grapples, before you buy.
/ Precision Mfg Mini322DBL Grapple Review #15
I'm definitely lovin' mine! It's an absolute beast. Build quality is excellent.
/ Precision Mfg Mini322DBL Grapple Review #16
I don't have Precision Manufacturing's grapple but I bought their Hi-Reach tree shear a long time ago. Well made, and the company has been good to work with on several product relate items since then.
/ Precision Mfg Mini322DBL Grapple Review #17
A pic of my grapple from post #12.
/ Precision Mfg Mini322DBL Grapple Review #18
Mad777 - be careful. You start using your tractor & grapple as a bulldozer- - something will crumple or break.
2020 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61568)
2020 Globe Trailer...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
2016 Ram 5500 Chassis 4x4 ETI ETC37IH 37ft Bucket Truck (A61568)
2016 Ram 5500...
New/Unused 3 Point Hitch (A61166)
New/Unused 3 Point...
New/Unused Quick Attach Hydraulic Rock Hammer (A61166)
New/Unused Quick...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
